I am trying to do my first pcb design, using the freeware version of eagle 6.5. I will be making a single layer board using toner transfer.
I did the routing of all the tracks, but didnt know better and used 90 degree angles. How do I change the existing tracks to use 45 degree bends without un-routing all the tracks, couldnt find an option in change menu.
Also, whats the best track width and track spacings for home made pcbs. current capability is not much of a concern. I am currently using 24mils for the track width, and whatever is set as default for track spacings.
I am using a couple of sot23 packages in this, hope home made pcbs can handle it. I am using these in mirrored mode to keep it on bottom layer.
