I'm new to electronics and I can work only with transistors. I'm trying to create a circuit that performs action like this:
Let's say I have 10 LEDs. When I supply power first LED lights, 0.5 sec later second LED lights and 0.5 sec later third LED lights and so on. But all the LEDs keep lighting during others light.
I want to know if it's possible or not. If possible please give a link to such a tutorial.
Thanks all for help.
It is possible using 10 bit Johnson counter with 2 Hz clock frequency, but it repeats the cycle after the last LED turns on (10th bit).
I added NAND gate(74LS00N) to the ckt for resetting all the states, when reaching the 10 bits are high,1 HZ signal can be generated by using 555 timer ckt
  • \$\begingroup\$ repeating the cycle after the last led is so good :) thanks for your answer! i will try it. But sorry i can't vote your answer up :( \$\endgroup\$ – Eldar Zeynalov Sep 8 '14 at 7:18
6
I would take a 555 square wave generator output from here 555 Oscillator Tutorial and drive shift register clock input from here The Shift Register. Shift registers input should high all the time.
The answer I personally use in my circuits:
Use a sawtooth voltage (i.e. from simple BJT sawtooth generator) and a ADC with LED driver (LM3914 comes to mind, can drive 10 LEDs, no resistors needed) - you only require 1 IC and LEDs to do the visual part, but you can easily change the behaviour of the LEDs by changing the voltage ramping (sine, tri) and frequency.
Also, you'll get a fully functional ADC/VU meter/voltage meter in the meantime, free of charge.
