6
I want to use some metal halide lamps (5-7*150W) to get some decent lighting in my room.
Unfortunately, inductors for these lamps have weight about 2kg each. I cannot accept 10kg of metal hanging near the ceiling :-) So I must go with electronic ballast, but their cost is about 100 bucks per lamp. Forking out 500 bucks does not sounds good.
So, I am thinking about making 5-channel electronic ballast for these lamps. While basic idea looks simple (just make constant current supply), the main problem is ignition.
Is it possible to avoid HV ignition by feeding RF signal into lamp, so that discharge would start just like in induction lamps, and after some time turn on the current?
And finally, do I still need alternating current direction in the lamp? If yes, how fast it should change?
    \$\begingroup\$ Making your own light fittings like that could cause problems if one caused a fire. Your insurance would be invalid. \$\endgroup\$ Apr 10, 2011 at 15:59
    \$\begingroup\$ 1kW, that's what I call decent lighting! :-) How about your ecological footprint? :-( \$\endgroup\$
    – stevenvh
    Apr 10, 2011 at 16:06
    \$\begingroup\$ Surely it would be regulated, so you can set it anywhere from 100 to 1kW :-) And with 100Lm/W efficiency, I am thinking that indeed 1kW is an overkill. So most likely will limit to 4 or 5 lamps. As for ecology - I don't own a car, so I guess I can afford 1kW lighting instead :-) \$\endgroup\$ Apr 10, 2011 at 16:10
  • \$\begingroup\$ You aren't setting up a cannabis farm, are you? \$\endgroup\$ Apr 25, 2011 at 15:06
  • \$\begingroup\$ Nope, just like light ) \$\endgroup\$ Apr 25, 2011 at 21:39
Don's Lighting Page has a lot of information on lamps from a DIY perspective. If there isn't a driver circuit listed in this site, you probably can't do it as a hobby.
  • \$\begingroup\$ Thanks, that covers most of my thoughts. I still have 1 question, probably going for phisics. \$\endgroup\$ Apr 26, 2011 at 11:14
Microchip has a dsPIC app note on electronic ballasts for automotive (not so different from what you have). They use an HV igniter to get the lamp fired. You will also see that AC is used once the lamp is fired.
A little research showed me that induction lamps don't have electrodes, and need HF applied constantly to excite mercury amalgam into emitting UV, whereas a metal halide lamp relies on an arc to be the UV source, and doesn't appear to have a mercury amalgam pellet at all.
It appears that the induction lamp is specially constructed so that the external electromagnet is close to the amalgam pellet. If there is no pellet in the HID lamp, game over. Even if there were, I don't know if you'd be able to excite it given the dimensions of the glass around it.
  • \$\begingroup\$ Nice document. 5 channel thing not going to be easy, but at least I don't have to step up from 12V :-) \$\endgroup\$ Apr 10, 2011 at 17:00
