I'm working on a library for STM32 to learn I2C protocol (Software I2C, not hardware).
I connect my DS1307 (Sparkfun BOB-12708) : (Here is the module schematic) :
  • I remove welding on the SJ2 jumper to dont use 4.7K embedded module pullup resistors.
  • I supply 5v power to the module
  • My STM32 board already has 4.7K pullup resistors to 3.3V
  • I connect module SDA and SCL to my STM32 3.3V GPIO with 15 cm cables.
  • I connect my two way oscilloscope to SDA and SCL.
I can produce a nice SCL (100KHz) and SDA signal except for the I2C "START CONDITION", SDA take time to fall down, the falling edge is not straightforward. When I increase timing in my code I can get the DS1307 address ACK. So I suspected the resistors values not be appropriate.
I used two different GPIO without pullup resistors and I use my own 1K pullup resistors to 3.3V and this work very well. Signal is nice I can read and write successfully to DS1307 and get date/time.
So I disconnect my oscilloscope, but after that, I could not read or write to the device :(. My oscilloscope impedance is 1M. If I leave 1K pullup resistor to 3.3V AND put a 1M resistor to ground this work.
I also try with bi-directional logic level converter (BOB-12009) and this work well but I want to use DS1307 directly without converter.
  • Can someone help me to understand why I need this 1M resistor ?
  • What 3.3V pullup resistors value can I use to only use pullup ?
Edit:
  • STM32 board is an Olimex STM32F103STK
  • Ground is connected between STM32, DS1307 (and oscilloscope when i plug it)
Edit 2:
My cable got bad ground wire connector, i replace the connector and now all work fine with or without oscilloscope and with 4.7K or 1K pullup resistors to 3.3V. Empirically 2.2K seem to be a good trade-off between current and clean signal edges.
  • \$\begingroup\$ Which STM32 module are you using? Are you connecting GND between the STM32 and the DS1307? \$\endgroup\$ – Adam Lawrence Sep 10 '14 at 15:46
  • \$\begingroup\$ Adam, thanks for reading. Yes ground is connected between STM32 and DS1307. \$\endgroup\$ – rom1nux Sep 10 '14 at 18:51
  • \$\begingroup\$ Too high pull-up resistor would make rising edge slower, not falling. Are you sure you are in open-drain output mode? \$\endgroup\$ – venny Sep 10 '14 at 19:56
  • \$\begingroup\$ Adam look right, this is a ground problem on câble. Problem solved with good cable... sorry to disturbe \$\endgroup\$ – rom1nux Sep 10 '14 at 20:31
