I'd like to build a very simple voltage comparator circuit with the following properties:
  • Vs = 5V
  • V- = Ground
  • Vout = 5V if V+ >= 200mV
  • Vout = 0V if V+ < 200mV
I'm using this comparator: NTE943M http://www.nteinc.com/specs/900to999/pdf/nte943.pdf
Any help is greatly appreciated.
  • \$\begingroup\$ Yes you can do that. Just apply a 200 mV reference voltage to the inverting input. Do you have a more specific question? \$\endgroup\$ – The Photon Sep 11 '14 at 0:34
  • \$\begingroup\$ My output doesn't go to 5V, do I need some pull up resistor or other feedback? \$\endgroup\$ – hagope Sep 11 '14 at 0:37
  • \$\begingroup\$ basically id like to detect a rising edge \$\endgroup\$ – hagope Sep 11 '14 at 0:41
    \$\begingroup\$ That's a crap datasheet (I'm pretty sure NTE doesn't make their own parts, just repackages other vendors' parts). You'd be better off to get a part with a better datasheet. But yes, it does look like you need a pull-up. \$\endgroup\$ – The Photon Sep 11 '14 at 0:48
The NTE934M is a copy of the LM393. Its outputs are 'open collector' and can only pull down. You need a pullup resistor (the datasheet suggests 1.5K).
| improve this answer | |
