16
I'm looking at triac datasheets, in particular this datasheet for BTA16 series triac. The "electrical characteristics" section is split into two parts: snubberless/logic level (3 quadrants) and standard (4 quadrants).
I have no idea what this is referring to. Are they different devices, as suggested by the column titles? Are they different operating modes? What is the difference?
11
NXP has a good explanation as to what the differences between 3-quadrant and 4-quadrant triacs are.
Summary: a 3-quadrant triac cannot be turned on in the fourth quadrant (T2 negative, G positive) which is beneficial when dealing with inductive loads - ringing caused by sudden turn-off could potentially turn on a 4-quadrant triac, necessitating snubbers and other protection means to prevent spurious conduction.
3-Q Triacs don't operate in 4th quadrant i.e positive gate current and negative load current. Please see the link I ve shared http://en.wikipedia.org/wiki/File:TRIAC_Equivalent_Circuit.png. You will get an insight of the working of a TRIAC
