Using Code Composer Studio and MSP430F5438A I get that error when compiling, but if I randomly delete some lines of the code, it will work fine. The problem is that I have not finished yet and there is more coming! What can I do?
EDIT: The whole code is:
#include <msp430.h>
#include "hal_lcd.h"
#include "string.h"
#include "math.h"
char data;
int brcnfg=0, dbcnfg=0, prtycnfg=0, sbcnfg=0, getfile=0,sendfile=0, print=0, index=0,
srescnfg=0,trescnfg=0, FrameLength=400, MatrixLength=200;
// Function prototypes
void BaudRateConfig(char data);
void DataBitsConfig(char data);
void ParityBitConfig(char data);
void StopBitConfig(char data);
/////////////////////////////////// Flash
char value; // 8-bit value to write to seg C
void write_SegC(char value);
void read_SegC(char data);
void copy_C2D(void);
void erase();
void sqr();
void circ();
unsigned char * Flash_ptr = (unsigned char *) 0x10000; // Initialize Flash pointer
long size[]={80000,80000,0,0,0,0,0,0,0}; // Files sizes
/////////////////////////////////// end Flash
int main(void)
{ WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
P5SEL |= 0xC0; // P3.4,5 = USCI_A0 TXD/RXD
UCA1CTL1 |= UCSWRST;
UCA1CTL0 |= UCMODE_0;
UCA1CTL1 = UCSSEL_1; // CLK = ACLK
UCA1CTL0 |= UC7BIT; // 7-bit characters
UCA1CTL0 &= ~UCSPB; // 1 StopBits
UCA1BR0 = 0x03; // 32k/9600=3.41
UCA1BR1 = 0x00; //
UCA1MCTL = UCBRS_3+UCBRF_0; // Modulation
UCA1CTL1 &= ~UCSWRST; // Release USCI state machine
UCA1IE |= UCRXIE; // Enable USCI_A0 RX interrupt
halLcdInit();
halLcdClearScreen();
// erase();
// Write the Square Path
sqr();
// Write the Circular Path
circ();
FCTL3 = FWKEY; // Clear Lock bit
FCTL1 = FWKEY+ERASE; // Set Erase bit
*(unsigned int *)Flash_ptr = 0; // Dummy write to erase Flash seg
while(!(WAIT & FCTL3));
FCTL3 = FWKEY+LOCK; // Set LOCK bit
__bis_SR_register(LPM0_bits + GIE);
__no_operation();
* main.c
// +++ USCI_A0_Interupt +++
#pragma vector = USCI_A1_VECTOR
__interrupt void USCI_A1_ISR(void)
if(__even_in_range(UCA1IV,18) == 0x02){ // Vector 2 - RXIFG
data = UCA1RXBUF;
// check if command
if (data == '*') // BaudRate Config.
brcnfg=1;
else if (data == '^') // DataBits Config.
dbcnfg=1;
else if (data == '$') // ParityBit Config.
prtycnfg=1;
else if (data == '#') // StopBit Config.
sbcnfg=1;
else if (data == '%' || data == '{'){ // Get File from PC
getfile=1;
if(data=='{')
print=1;
else if (data == '@'){ // EOF
while(!(UCA1IFG & UCTXIFG));
UCA1TXBUF='@'; // Send Acknowledge that the file has been received
index++;
getfile=0; // Exit the file transfer mode
print=0;
else if (data=='&'){ // Send File to PC
sendfile=1;
else if(data=='<'){ // Finished sending the file to PC
while(UCA1STAT & 0x01);
halLcdPrint("PC: The file has been received",'2');
halLcdScrollRow(1);
else if(data=='>') // Change square resolution
srescnfg=1;
else if(data=='}') // Change time resolution
trescnfg=1;
else{ // implement the command or just do echo
if(brcnfg){ // BaudRate Config.
UCA1TXBUF='*'; // Send Acknowledge to PC
BaudRateConfig(data);
brcnfg=0;
else if(dbcnfg){ // DataBit Config.
UCA1TXBUF='^'; // Send Acknowledge to PC
DataBitsConfig(data);
dbcnfg=0;
else if(prtycnfg){ // Parity Bit Config.
UCA1TXBUF='$'; // Send Acknowledge to PC
ParityBitConfig(data);
prtycnfg=0;
else if(sbcnfg){ // Stop Bit Config.
UCA1TXBUF='#'; // Send Acknowledge to PC
StopBitConfig(data);
sbcnfg=0;
else if (getfile){ // Write to Flash
/*while(!(UCA1IFG & UCTXIFG));
UCA1TXBUF=data;
if(print)
halLcdPrint(data,'2');*/
while(UCA1STAT & 0x01); // ???????
write_SegC(data);
else if (sendfile)
read_SegC(data);
else if (srescnfg){ // srescnfg=SquareResolutionConfiguration // TEMPORARLY !!!!!!!!!!!!!!!!!!
MatrixLength=sqrt(FrameLength*FrameLength/data);
srescnfg=0;
UCA1TXBUF='>'; // Send Ack for changing square resolution
else if (trescnfg){ // trescnfg=TimeResolutionConfiguration
UCA1TXBUF='}'; // Send Ack for changing time resolution
else{
/*while(UCA1STAT & 0x01);
halLcdPrintLine("MCU: ",'2');*/ // Chat
UCA1TXBUF=data;
void BaudRateConfig(char data){
if (data=='9'){ // 9600 BaudRate Configurations
UCA1BR0 = 3;
UCA1BR1 = 0;
else if (data=='4'){ // 4800 BaudRate Configurations
UCA1BR0 = 6;
UCA1BR1 = 0;
UCA1MCTL = UCBRS_7+UCBRF_0;
else if (data=='2'){ // 2400 BaudRate Configurations
UCA1BR0 = 13;
UCA1BR1 = 0;
UCA1MCTL = UCBRS_6+UCBRF_0;
else if (data=='1'){ // 1200 BaudRate Configurations
UCA1BR0 = 27;
UCA1BR1 = 0;
UCA1MCTL = UCBRS_2+UCBRF_0;
void DataBitsConfig(char data){
if(data=='8')
UCA1CTL0 &= ~UC7BIT; //8-bit characters
else if (data=='7')
UCA1CTL0 |= UC7BIT; //7-bit characters
void ParityBitConfig(char data){
if(data=='N')
UCA1CTL0 &= ~UCPEN; // Parity Disable
else if(data=='E')
UCA1CTL0 |= UCPEN + UCPAR; // Parity Enable
else if(data=='O'){
UCA1CTL0 |= UCPEN; // Parity Enable
UCA1CTL0 &= ~UCPAR;
void StopBitConfig(char data){
if(data=='O')
else if(data=='T')
UCA1CTL0 |= UCSPB; // 2 StopBits
// Input = value, holds value to write to Seg C
//__disable_interrupt(); // 5xx Workaround: Disable global
// interrupt while erasing. Re-Enable
// GIE if needed
FCTL1 = FWKEY+WRT; // Set WRT bit for write operation
*Flash_ptr++ = data; // Write value to flash
size[index]++; // Calculating the file size
FCTL1 = FWKEY; // Clear WRT bit
char temp=data;
unsigned char * Flash_ptrTemp;
// Square Path
if(temp==0)
Flash_ptrTemp = (unsigned char *) 0x10000;
// Circular Path
else if(temp==1)
Flash_ptrTemp = (unsigned char *) 0x23880;
else{
Flash_ptrTemp = (unsigned char *) 0x27100;
// Choose the right file to send to PC
char k='0';
while(temp!='2'){
Flash_ptrTemp = Flash_ptrTemp + size[k-48];
k++;
temp--;
long i;
// Send the file by sending char-by-char
for(i = 0; i < size[data-48]; i++)
UCA1TXBUF=*Flash_ptrTemp++;
// Stop sending file mode
sendfile=0;
// Send EOF
UCA1TXBUF='&';
void erase(){
while(Flash_ptr < (unsigned char *)0x40000){
Flash_ptr += 0x200;
void sqr(){
unsigned char counter='0';
unsigned char sqrMatrix[MatrixLength][2*MatrixLength];
// First line
int j;
for(j=MatrixLength; j>5;j=j-2){
sqrMatrix[counter][j]='@'; // 64 Decimal
sqrMatrix[counter][j+1]=counter;
counter++;
// Obstacle
sqrMatrix[counter][5]='A'; // 65 Decimal
sqrMatrix[counter][6]=counter;
counter++;
// Start the second line ;)
for(j=7;counter<255;j=j+2){
counter++;
// The counter has reached 255->start filling also in the MSB bit.
for(j=0; j<MatrixLength;j=j+2){
unsigned char MSB=counter/255;
unsigned char LSB=counter%255;
sqrMatrix[counter][j]='@'+MSB; // 64 Decimal
sqrMatrix[counter][j+1]=LSB;
counter++;
unsigned char backCount=counter;
// Obstacle
sqrMatrix[backCount][2*MatrixLength/2]='A'; // 65 Decimal
sqrMatrix[backCount][2*MatrixLength/2]=counter;
counter++;
backCount--;
// draw the 3rd line
for(j=(2*MatrixLength/2)+2;j<2*MatrixLength-5;j=j+2){
sqrMatrix[backCount][j]='@'+MSB; // 64 Decimal
sqrMatrix[backCount][j+1]=LSB;
counter++;
backCount--;
// Obstacle
sqrMatrix[backCount][2*MatrixLength/2-6]='A'; // 65 Decimal
sqrMatrix[backCount][2*MatrixLength/2-5]=counter;
backCount--;
// draw the last line
for(j=2*MatrixLength-7;j>2*MatrixLength/2;j=j-2){
counter++;
backCount--;
int i;
for(i=0;i<MatrixLength;i++)
for(j=0;j<MatrixLength*2;j++)
write_SegC(sqrMatrix[i][j]);
void circ(){
printf
etc? I'm not sure how to enable it under CCS but they'd almost certainly be a linker map that you can enable to see how much memory is being used by various parts of the code. \$\endgroup\$ – PeterJ Sep 12 '14 at 6:45
