I want to design the SMPS with the following specifications-
- 5V DC,5Amax,1Amin
- 12V DC,5Amax,1Amin
- using BUCK converter.
- Vin DC=24V
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI want to design the SMPS with the following specifications-
I'm assuming you have an input voltage of 24 volts (say 23 volts to 25 volts) and you want two outputs; one at 5V (and 5A) and one at 12V, 5A.
The simplest (possibly) way involves going to Linear technology's buck converter page and plugging in the numbers for both outputs. The dat entry area above should be setup for an input voltage matching your requirements and 12v for the 1st output. It suggests many devices to choose from.
The LT8612 looks good for 5V (or 12V) at 6A and the LT3845A looks able to provide 12 volts at over 6 amps. There are others on the page also worth looking at.
Should you be wanting a bargain-basement low cost product you didn't say so I went for the technology that I know to be probably the best and one of the devices (LT8612) I've used successfully in a couple of designs.
