I wrote a program in AVR ASM for converting 32-bit unsigned binary numbers to 8 digit decimals based on the shift-add-3. (I know that 32-bit is more than 8 digit, but I only need 8.)
The 32-bit input is in R16-R19 (low-high).
The 8 digit output is in R20-R24 (low-high), 2 number / byte, one in the lower nibble, one in the higher nibble.
My problem: It takes ~1500 cycles to compute a 16-bit number and ~2000 cycles to compute a 32-bit.
Can anybody suggest me a faster, more professional method for this? Running a 2000 cycle procedure on a ATtiny at 32,768 Khz is not something I am comfortable with.
Memory usage map:
Memory map for BinaryToBCD
Definitions:
.def    a0  =   r16
.def    a1  =   r17
.def    a2  =   r18
.def    a3  =   r19
.def    b0  =   r20
.def    b1  =   r21
.def    b2  =   r22
.def    b3  =   r23
.def    i   =   r24
.def    j   =   r25
The code:
BinaryToBCD:
    clr     b0
    clr     b1
    clr     b2
    clr     b3
    ldi     i,  32
    sts     0x0068, i       ;(SRAM s8)
BinaryToBCD_1:
    clc
    rol     a0
    rol     a1
    rol     a2
    rol     a3
    rol     b0
    rol     b1
    rol     b2
    rol     b3
    lds     i, 0x0068       ;(SRAM s8)
    dec     i
    brne    BinaryToBCD_2
    ret
BinaryToBCD_2:
    cpi     b0,     0
    breq    BinaryToBCD_3
    mov     i,      b0
    rcall   Add3ToNibbles
    mov     b0,     i
BinaryToBCD_3:
    cpi     b1,     0
    breq    BinaryToBCD_4
    mov     i,      b1
    rcall   Add3ToNibbles
    mov     b1,     i
BinaryToBCD_4:
    cpi     b2,     0
    breq    BinaryToBCD_5
    mov     i,      b2
    rcall   Add3ToNibbles
    mov     b2,     i
BinaryToBCD_5:
    cpi     b3,     0
    breq    BinaryToBCD_1
    mov     i,      b3
    rcall   Add3ToNibbles
    mov     b3,     i
    rjmp    BinaryToBCD_1
Add3ToNibbles:
    mov     j,      i
    andi    j,      0b00001111
    cpi     j,      5
    in      j,      SREG
    sbrs    j,      0
    subi    i,      -3
    mov     j,      i
    swap    j
    andi    j,      0b00001111
    cpi     j,      5
    in      j,      SREG
    sbrs    j,      0
    subi    i,      -48
    ret
  • \$\begingroup\$ What about a look-up table and exploiting the fact that it is triangular? \$\endgroup\$
    – venny
    Sep 15 '14 at 10:08
  • \$\begingroup\$ Wh not use faster internal oscillators? \$\endgroup\$
    – Golaž
    Sep 15 '14 at 11:47
  • \$\begingroup\$ Please tell me more about the table and the "triangularity", I do not know what you mean. Cannot use faster Osc, because this chip manages time and date also. 32768 is the highest-precision, with this I only need 16*2 bit overflow on the timer. \$\endgroup\$ Sep 15 '14 at 15:35
    \$\begingroup\$ @GáborDani What I meant was to have an array of decimal numbers with one byte per digit for every 2^n, like (3,2,7,6,8),(1,6,3,8,4),(0,8,1,9,2). Then you go through the individual bits of the binary number and add the numbers to 8-byte long array (one byte for every digit). As you go from bit 31 to 0, the decimals get shorter so less additions are required(that is what i meant by triangularity). \$\endgroup\$
    – venny
    Sep 15 '14 at 16:01
  • \$\begingroup\$ i would try to write it in c and look at the output of the compiler (do not forget to switch on optimization) to maybe learn some tricks to apply on my own code \$\endgroup\$ Apr 5 '15 at 20:37
This is based on venny's approach (venny called it triangulation), expressed on a "pseudo-C":
uint32 x; // input variable to convert
w = { 2, 1, 4, 7, 4, 8, 3, 6, 4, 8 }; // 2^31
r = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }; // initial result = 0
for (i = 31; i >= 0; i --)
   if ( 2^i  AND x )  // is x's bit i up?
      add(r, w);      // if yes, 1 ASCII ADD and 9 ASCII ADD w/CARRY MAX
   divide(w, 2)       // 10 SHIFT RIGHT MAX
Routines add and divide are not needed explanation, imo.
There are a number of papers and application notes on the subject. For example, http://www.element14.com/community/servlet/JiveServlet/downloadBody/47820-102-3-258641/Cypress.Application_Notes_35.pdf
