So I have an ATmega328P with a 14.7456MHz external crystal, full-swing settings, and I'm trying to talk to my mac via UART and an FTDI friend-type device.
If I connect AVR Tx to AVR Rx, then all bytes come through perfectly (I can view it on some 7-set displays). If I connect FTDI Rx to FTDI Tx, then all bytes come through perfectly (viewed on Arduino serial monitor). The baud rates of both devices are the same.
However, when I connect them together ...
Serial monitor gets data (scroll bar appears and starts scrolling across), but no characters are displayed. It's as if they are all spaces (I send 'a', or an arbitrary 8 bit number). If I select half the baud rate, then weird characters appear, but not what I send.
AVR receives characters (receive interrupt fires), but what it receives is either 0, or the same number (eg. 173, but it seems rather random) for any character I send.
I've googled and googled, and have found no solution to this. Any ideas? Help on this is much appreciated. (hopefully I've provided enough information)
