12
So i am designing a device that is supposed to connect to the PC via USB and draw power from the VBUS (+5v) of the USB.
I am wondering if I need to put a voltage regulator in between the +5v from the USB and the microcontroller on my device. I've tested this device on my own laptop and it works fine. But I'm not sure if I can make any assumption regarding the stability of the VBUS on other computers. I looked at some Arduino designs and they don't seem to place any voltage regulator when it is powered through the USB.
So is it safe to assume that the +5v coming from a PC USB connection is fairly stable?
  • \$\begingroup\$ I would worry a bit about stability. On charge, my laptop has a 4.97V USB output. On the battery near the end of the discharge cycle, it drops to 4.75V. \$\endgroup\$
    – Thomas O
    Commented Apr 12, 2011 at 18:22
12
The USB specification states that the 5v is supposed to be +-5% under load, which translates to 4.75v to 5.25v. A simple power connection will provide up to 100 ma. (Up to 500 ma can be drawn, but you have to negotiate for it.).
Most IC's designed for 5v should accommodate the +-5% variation also.
  • \$\begingroup\$ is this possibly very outdated? With USB 3.0, it seems at least possible to draw more than 500ma... without any further specification (and ambiguous linked source) this can be a bit misleading \$\endgroup\$ Commented Feb 2, 2021 at 22:09
8
The 5 V VBUS is definitely not stable, and will usually vary with the computer's load. In USB audio products, this creates all kinds of noise, presumably from audio frequency fluctuations caused by video cards, hard drives, etc. For these applications, a regulator is necessary. With your micro, it probably doesn't matter, but if you're doing any kind of analog to digital conversion, I'd also recommend a regulator.
The USB spec lists a worst-case drop of 4.375 V at the device, after a bus-powered hub, with transient drops to 4.07 V. Keep in mind that not every USB host follows the USB spec, so it could be even worse.
Wikipedia summarizes:
It is specified that devices' configuration and low-power functions must operate down to 4.40 V at the hub port by USB 2.0 and that devices' configuration, low-power, and high-power functions must operate down to 4.00 V at the device port by USB 3.0.
Provided you are using a computer as a source, then yes you can assume that the 5V is stable.
You cannot assume this if you use a mains power supply adaptor with a USB output, like the one that comes with an Apple iPhone.
Also, to use a regulator effectively, you should supply the regulator with a slightly higher voltage than the regulator output, otherwise as soon as you put a load on it there won't be enough 'spare voltage' for it to draw from to maintain +5V. (I know that's a bad way of saying it but it kinda makes it easier to understand!).
    \$\begingroup\$ Why the concern about the mains power supply adapter? I assumed they had a regulator or switcher in them. \$\endgroup\$ Commented Apr 12, 2011 at 17:48
  • \$\begingroup\$ i think it's more logically if the port is getting older. thus we need extra power supply adaptor as you said. \$\endgroup\$
    – gumuruh
    Commented Aug 18, 2021 at 7:24
