I bought these LEDs from eBay and connected them all (5) in parallel with a 4.7 ohm series resistor each.
This should have given me a total current draw of 1.7A, but when I measured it I was only getting 0.4A.
I then connected an LED directly (via the multimeter) to the 5V power supply, expecting the LED to blow. Instead, the LED drew 0.7A, as specified in the description. There is no datasheet, and I'm unfamiliar with LEDs having a current regulator built in.
So why didn't my LEDs blow?
In case the link dies in the future, here are the specs:
- Forward Voltage:3.2-3.4V
- Forward Current:700MA
Edit: I did the following test measurements. There are some discrepancies I believe which are associated with the quality of the multimeter I am using.
Note: The voltage measurements were done with the 'ammeter' removed.
- \$I_{circuit} = 230mA\$
- \$V_{supply} = 4.95V\$
- \$V_{led} = 3.3V\$
- \$V_r = 1.23V\$
- Ground pad: Warm
- \$I_{circuit} = 140mA\$
- \$V_{supply} = 5.05V\$
- \$V_{led} = 3.17V\$
- \$V_r = 1.63V\$
- Ground pad: Warm
- \$I_{circuit} = 650mA\$
- \$V_{supply} = 4.63V\$
- \$V_{led} = 4.63V\$
- Ground pad: Very hot.
Further note, that the LED when directly connected to the power supply, without the ammeter still does not die (held for 5 seconds.)
The LED is soldered onto a PCB like so:
