I have been wondering about Beagleboard and it's possibilities of supporting many embedded OSes
What I was wondering was:
- Using a SSD as a SD Card? Does it depend on the OS?
- Relocation of the Usb ports?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have been wondering about Beagleboard and it's possibilities of supporting many embedded OSes
You can run a lot of different OS on the Beagleboard, but set it up to do Multiboot is probably a little bit tricky.
I think the easiest is to have a couple of different SD cards and switch the card when you need another OS on the board.
