In this problem I'm trying to find the Thevenin resistance in the circuit below:
The first thing we do is remove all sources and the load resistor. So now we have the following circuit:
The part I'm stuck on is computing the total resistance between the load terminals a and b. If I remove R4, I can figure it out; R2, R7, and R8 all terminate at the ground node. We have R2 and R7 in parallel, which is in series with R5, which is in parallel with R8. Thinking of it this way, but then adding R4 into the mix, doesn't R4 begin and end at the same node?
  • \$\begingroup\$ Yes it does. Since it's shorted out, does that suggest something? \$\endgroup\$ Sep 18, 2014 at 0:29
    \$\begingroup\$ @SpehroPefhany, so that means the current would prefer to flow through the wire than the resistor, so it's like the resistor isn't even there. Right? \$\endgroup\$
    – Lefty
    Sep 18, 2014 at 0:30
  • \$\begingroup\$ Exactly correct. \$\endgroup\$ Sep 18, 2014 at 0:43
  • \$\begingroup\$ I think of it this way: a resistor in parallel with a short (a 0 ohm resistor) has a resistance of R // 0 = (R * 0) / (R + 0) = 0 ohms. That means you can ignore R4. \$\endgroup\$
    – Greg d'Eon
    Sep 18, 2014 at 0:44
  • \$\begingroup\$ Why shorted resistor is ignorable? \$\endgroup\$
    – Amit Hasan
    Sep 18, 2014 at 1:53
You can use T to Pi transformation which would make things a little more practical. Reference to : Pi and T networks .
Hope it helped.
