6
Recently, I heard one of my colleague said "the 16-bits ADC is enough for us, we can use 'oversampling' tech...". Finally I figured out his "oversampling tech" means to sample many many cycles (AC sampling). But I wonder if we don't improve the sample rate, what is the benefit from sampling many cycles? Can it increase the resolution of the ADC? So my question is:
  1. I think "oversampling" means to improve the sample rate. Right?
  2. What is the benefit from multiple cycle sampling?
My colleague's "oversampling" is as below:
If we want to measure 50 Hz AC signal, we set ADC's sample rate to 1000 Hz, and sample 10 cycles, that is (1000 Hz / 50 Hz) x 10 = 200 samples. If the result is not good, increase the cycles to 100, etc. Yes, he only increases the samples, but not the sample rate!
    \$\begingroup\$ For some further reading Atmel have an application note here worth checking out: AVR121: Enhancing ADC resolution by oversampling \$\endgroup\$
    – PeterJ
    Sep 18, 2014 at 10:20
    \$\begingroup\$ It seems you are confusing over sampling (A higher than needed sample rate.) With signal averaging. (Recording the same repetitive signal many times and then taking the average.) Maybe your colleague is confused a bit too? \$\endgroup\$ Sep 18, 2014 at 13:01
  • \$\begingroup\$ @GeorgeHerold: Yes, i think my colleague make a mistake about 'oversampling' and 'averaging'. \$\endgroup\$
    – diverger
    Sep 18, 2014 at 13:12
11
Oversampling means to sample at significantly more than the Nyquist Rate.
When using an ADC, the ADC generates quantisation noise because the continuous valued signal has to be translated to discrete output values. If you oversample then this noise power is "spread out" over a larger frequency range, i.e. it has a lower spectral density. So if you apply a digital low-pass filter after the ADC you can reduce the total noise. The reduction would be -3dB if you halved the bandwidth of the signal, which is equivalent to 1/2 bit improvement in your ADC. So oversampling by 16x and filtering with a perfect brick wall LPF would give you an improvement of 4*1/2 bit = 2bits.
Intuitively so you can see this works: say the ADC output is oversampled by 4 so for a specific sample you get 3,4,3,3 ; the average of this is 3.25 so you have improved the effective number of bits (ENoB) of your ADC reading.
Delta-Sigma ADCs shape the quantisation noise, pushing more of it out to higher frequencies so they can get 2 or even 3 bits per octave of oversampling. This diagram (from EETimes) illustrates the point:
On your point (2) you refer to "multiple cycle sampling" as "means to sample many many cycles (AC sampling)".
Your description is a little confusing, but you can use techniques that rely on sampling a repetitive signal over multiple cycles to "fill in" samples that fall in between the sample rate. Digital Sampling Oscilloscopes use this technique. Basically you sample your signal starting from time 0 and then sample again from time T/N (either on stored data or the next input signal cycle), where T is the sample period and N is the oversample rate. You then "fill in" the new data.
EDIT: Based on OP clarification: "If we want to measure 50 Hz AC signal, we set ADC's sample rate to 1000 Hz, and sample 10 cycles, that is (1000 Hz / 50 Hz) x 10 = 200 samples. "
By sampling the same points from a periodic perspective you will get some noise reduction once you average the values as described in my answer, but the noise reduction will not match the theoretical reduction because the quantisation noise will be correlated to the sampling. Also, you're missing a trick if you do not recognise the point I made in (2). By choosing the sample frequency to be relatively prime with respect to the signal frequency you would not be sampling the "same points" each period. This gives you more data. If you then choose to average this you get less noise because the quantisation noise will be de-correlated.
The minimum sampling rate needed is twice the highest frequency of the spectrum of the signal you wish to measure. If the highest frequency in the spectrum of the signal is 10kHz then you need to sample at least twice as high (20,000 times per second) in order to avoid aliasing.
Most folk go a bit better than this and, for instance, CD's sample audio at 44.1k samples per second and expect to be able to reproduce an audio spectrum that goes from DC to 20kHz. that's 2.205 times higher than 20kHz. Here's an example picture: -
It shows a benefit for oversampling in that the filtering used to recover an audio signal after a DAC is more easily designed and uses fewer components (take my word for it). I'm involved a lot with sampling analogue signals and we place a minimum sampling rate at 2.5 times to make reconstruction of the signal after leaving the DAC a relatively easy process.
Under-sampling is to be avoided unless you are designing (eg) software radios which rely on under-sampling as a means for demodulation. This is what happens: -
The red signal is the original and it is under-sampled at the blue-dot points - when this is reconstructed by a low pass filter the blue signal is generated and clearly this does not look like the original signal! If you sampled a sine wave exactly at twice its frequency then you'll get a dc level somewhere between -pk and +pk.
Strictly speaking, both CDs and the systems I work on "over-sample" and of course everyone else does to a lesser or greater extent.
So, the benefit of over-sampling is: -
  • improved signal-to-noise ratio,
  • ability to recover signals that are less than one quantization step in amplitude (called dithering and also used in digital audio on CDs),
  • simpler reconstruction filters (analogue and digital domain),
  • DAC sinc-compensation filter less likely to be needed.
I'm not going to go too deep into this as you are probably a beginner in this subject but please ask if you need more info.
EDIT - following the amendment by the OP: -
Sampling more cycles of a 50Hz waveform may or may not give you what you want. For instance, the RMS value from one cycle can be calculated as X but the next cycle it could be fractions higher or lower. Another problem is that sampling several cycles (or even 1 cycle) may result in only a partial coverage of exact cycles and this will give another error. How you would know that the result is not good is another thing and this I rely on the OP in explaining.
One thing can be said though, if the signal is stable (frequency and voltage and shape) over several cycles, then sampling more cycles improves accuracy.
  • \$\begingroup\$ Also called the "Nyquist-frequency" mathworld.wolfram.com/NyquistFrequency.html. \$\endgroup\$
    – loveNoHate
    Sep 18, 2014 at 10:41
  • \$\begingroup\$ That's a nice (if somewhat long-winded) explanation of the Nyquist criterion, but it misses the point of the question. In common usage, "oversampling" means sampling at greater than 2x Nyquist, so that at least some of the filtering can be done in the digital domain. Or, in conjuction with a suitable dithering signal (and this is the actual point of the question), the effective resolution of the converter can be increased. \$\endgroup\$
    – Dave Tweed
    Sep 18, 2014 at 11:44
  • \$\begingroup\$ @DaveTweed I don't think you are correct (for once!). I read the OP's question to be about oversampling and possibly about under-sampling - note "what we can benefit from many many cycles sampling" - I read into this the distinct possibility of under-sampling and "clever" reconstruction of the original signal. Having said that, the OP isn't that clear about this so I went for a general answer that tried to cover sampling either side of the 2x rate. The OP may actually be asking about clever under-sampling techniques as used in some oscilloscopes to display a much faster signal. \$\endgroup\$
    Sep 18, 2014 at 11:54
    \$\begingroup\$ Gthe OP's edit, it turns out we're both wrong -- he's really asking about signal averaging -- combining multiple cycles of a repetitive signal to obtain higher resolution in both voltage and time (assuming the sampling is not correlated with the signal). \$\endgroup\$
    – Dave Tweed
    Sep 18, 2014 at 13:34
