So I recently bought a motorised pedicure set thinking it would be some amazing thing. However, I used it once and the batteries (4 AA) died after about half an hour and not before getting ridiculously hot.
I decided I would take it apart to see what mad electronics have gone into it, and it turns out it is literally just a button and then wired straight into the motor. So I have decided I would like to replace the motor with one that has a higher torque (was really not very powerful so didn't have much effect) as well as possibly a higher RPM.
After taking it apart and finding the motor, I tried to find out what type of motor it currently is but it has no markings or part numbers on it at all so I couldn't find out. I wanted to know this so I could know the characteristics of it and things like that so I know how to get a better motor that would provide a better product!
Here are some pictures of the motor in various stages of assembly and I was wondering if anyone could help out with regards to what type of motor it is, and if anyone has any comments/solutions to some of the issues I mentioned they would also be greatly welcomed!
enter image description here enter image description here enter image description here
As it might not be clear from the pictures, inside the 'drum' of the motor are two magnets that the coiled wire sits in.
I have taken the voltage and current readings of it and it is as follows:
Voltage: Anywhere between 4V - 12V it seems to work, towards 12V it starts going a little bit mental.
Current: Around 500 - 600mA.
  • \$\begingroup\$ Carbon brushes? \$\endgroup\$ – Andy aka Sep 18 '14 at 11:45
  • \$\begingroup\$ It is an ordinary brushed DC motor. To find a suitable replacement, you need at least to measure its operating voltage. RC hobby shops will almost certainly have something similar and more powerful than this. \$\endgroup\$ – venny Sep 18 '14 at 11:50
It's just an ordinary brushed DC permanent-magnet motor.
| improve this answer | |
It is a DC motor, like those used in radio-controlled toys or models. This in particular is a permanent magnet motor. You should try to determine the supply voltage.
Append: For a 6V DC motor, maybe this is a good reference.
  • \$\begingroup\$ It's running off of 4 AA batteries so it must be rated for 6 volts. \$\endgroup\$ – Barry Sep 18 '14 at 13:10
You don't want a motor with higher torque. The torque is low on purpose.
If it had higher torque, you could grind right through a finger nail or the tip of your finger - ouch. Even a buffing wheel could rub hard enough to get painfully hot.
If the motor is really horrible (real cheap trash) then you might need a better motor - but then I'd suggest a current limiter to keep the torque down.
