-6
Explain the following equation...
$$ r^{\prime}_d = \dfrac{26\mathrm{mV}}{I_D} + r_B $$
Explain from where and how this equation comes out . Also elaborate the terms used in above mentioned equation.
closed as unclear what you're asking by Matt Young, Leon Heller, Scott Seidman, Alfred Centauri, user17592 Sep 18 '14 at 19:30
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Explain the question \$\endgroup\$ – ACD Sep 18 '14 at 17:33
    \$\begingroup\$ Sounds like homework. \$\endgroup\$ – Ignacio Vazquez-Abrams Sep 18 '14 at 17:34
    \$\begingroup\$ Can you give more context? The equation is like of the dinamic resistance for a polarized P-N junction... right? \$\endgroup\$ – Martin Petrei Sep 18 '14 at 17:35
    \$\begingroup\$ Homework questions with no attempt at a solution are closed. \$\endgroup\$ – Leon Heller Sep 18 '14 at 17:36
  • \$\begingroup\$ Sir,it;s not homework question.I just read it and don not understand that's why I asked. \$\endgroup\$ – Ali Awan Sep 18 '14 at 17:39
If it is the dynamic resistance of the diode, \$r_d\$ is the value of this resistance, when the diode is forward biased with a current \$I_D\$.
This starts from the analysis of the diode equation
$$ I = I_s\cdot \left(e^{\dfrac{q_e\,V}{\eta\,K\,T}} -1\right) $$
and defining the dynamic resistance as
$$ r_d = \dfrac{dV}{dI} $$
replacing \$K\$ for the Boltzmann's constant, \$T\$ the temperature, \$\eta\$ a coefficient between 1 y 2, \$q_e\$ the electron charge and \$I_s\$ the saturation current (minoritary carriers), an aproximate value is
$$ r_d \approx \dfrac{26\,\mathrm{mV}}{I} $$
You can find a more detailed explanation here
