As in from homework problem:
Plot this function in K-map:
\$F(A,B,C,D,E)\$ is 1 if the number represented by the 5-tuple (A,B,C,D,E) is even or divisible by 3.
Does this mean I should treat each word as a binary number? For example:
\$F(0,1,1,0,0) = 1\$ because 01100 is even number.
\$F(0,1,0,0,1)= 1\$ because 01001 is 9 in decimal and 9 is divisible by 3.
  • \$\begingroup\$ I think there's more information needed to answer this. Is there any context about how to construct a number from A, B, C, D, and E? I don't feel like it's a given that each letter represents a binary bit. \$\endgroup\$
    – Dan Laks
    Commented Sep 19, 2014 at 21:00
  • \$\begingroup\$ I take that back... if this is a Karnaugh Map, then they probably are binary bits. \$\endgroup\$
    – Dan Laks
    Commented Sep 19, 2014 at 21:09
  • \$\begingroup\$ That's all it says on the problem. Nothing in the textbook explains anything about tuples. I tried to look around the internet and I couldn't find anything either. And yes, they are binary bits. \$\endgroup\$
    – vxs8122
  • \$\begingroup\$ Based on this wikipedia example, I suspect your approach is correct: en.wikipedia.org/wiki/Karnaugh_map#Example \$\endgroup\$
    – Dan Laks
    Commented Sep 19, 2014 at 21:11
  • \$\begingroup\$ I believe that your approach is right - this is what I've done in the past for divisibility problems with k-maps. \$\endgroup\$
    – Greg d'Eon
    Commented Sep 19, 2014 at 21:24
"Tuple" is math-speak for an ordered array of elements. "Number represented by the ...-tuple" in the context of boolean variables does in fact refer to a binary number whose bit positions match the variables within the tuple, with the rightmost element being the LSb and the leftmost being the MSb.
