-1
I saw the discussions about conductive fabric with the links to lessemf.com and others. I'd like to get anyone's thoughts about painting a schematic on cloth using welding conductive primer such as SEM copper weld-through primer (Product Code #: SEM40783) that I found at http://www.nationaltoolwarehouse.com. Since that works for welding, would it work for soldering wires to it? Thanks, Don
    \$\begingroup\$ Does it have any constituent which would bond it to the material? I.e. Why would it not simply fall off after a few minutes? \$\endgroup\$ – gbulmer Sep 20 '14 at 17:37
There are conductive glues and silicones available like this one. You could bond wires (and components) to fabric with a conductive glue and use any other paintable conductive material that remains flexible after drying to lay out a circuit. The printing/painting resolution probably wouldn't be great so circuit complexity and density would be constrained, but I see no obvious reason why it couldn't work.
