I've ran into a slight confusion.
The equation for resistance in a parallel circuit should work for any number of resistors, I assumed. So when I'd have 2 resistors in parallel, total Rt would be: Rt = 1/G and G=1/Ra + 1/Rb
Now my book says, for 2 resistors in parallel, you may use this formula too: Rt = (Ra * Rb) / (Ra + Rb)
When I fill in 100 Ohms for Ra, and 220 Ohms for Rb, the two equations produce different results. (68.75 for the first, and 66.67 for the second). Now, I have tried it with several sets of values, but I couldn't reproduce this difference with those.
What is happening!? I'm lost!
Edit: Yeah, I've been miscalculating indeed. How embarrassing to find out this way. Thanks for all your answers :)
  • \$\begingroup\$ Please check your maths. Those equations are mathematically equivalent. I get 66.67 if I wrongly enter the Ra+Rb as 230 Ohms instead of 220. \$\endgroup\$
    – akellyirl
    Sep 22, 2014 at 11:03
  • \$\begingroup\$ I got the same as @akellyirl - and then read his answer. ie 100 x 220 / (100+**230**) = 66.67 . ie you have simply misentered one figure. \$\endgroup\$
    – Russell McMahon
    Sep 22, 2014 at 11:05
  • \$\begingroup\$ If you get a "wrong" answer ALWAYS recalculate and watch your input. Best is to try to find some other way to enter the data. eg here you could try 22000/320 as doing that much "in your head" is easy \$\endgroup\$
    – Russell McMahon
    Sep 22, 2014 at 11:08
  • \$\begingroup\$ I sometimes make mistakes with a dumb-calculator, so I use a spreadsheet or a calculator which records every step (on my Mac). The spreadsheet is a very good approach as I can ensure the same values are always used. It saves a lot of gnnnnnggg. \$\endgroup\$
    – gbulmer
    Sep 22, 2014 at 11:17
What is happening!?
You made a calculation error.
$$\frac{100 \cdot 220}{100 + 220} = \frac{1}{\frac{1}{100} + \frac{1}{220}} = 68.75$$
It's easy to show the equivalence of the two formula:
$$\frac{1}{\frac{1}{R_1} + \frac{1}{R_2}} = \frac{1}{\frac{1}{R_1} + \frac{1}{R_2}}\frac{R_1\cdot R_2}{R_1\cdot R_2}=\frac{R_1\cdot R_2}{R_1 + R_2}$$
  • \$\begingroup\$ Yep... It just took me a while to find out.. adding 100 and 220 to 330 felt so natural at the time \$\endgroup\$
    – Smokez
    Sep 22, 2014 at 11:06
