The figure below is a AM demodulator. My instructor told me to chose RC so as to satisfy the following inequality :
Tc << RC << Tm
Where Tc is the period of the carrier wave and Tm is the period of the message signal. I found that RC should be the geometric mean of Tc and Tm.
Why is this true? Why is the best value near the geometric mean?
  • \$\begingroup\$ What have you figured out so far? In particular, what would be considered the 'best'? \$\endgroup\$ Commented Sep 24, 2014 at 6:40
  • \$\begingroup\$ I found that the demodulator works the best around the geometric mean. If its too small the capacitor has very less time to discharge and it follows the carrier wave and if too big the capacitor follows the message signal. \$\endgroup\$
    – Timmy
    Commented Sep 24, 2014 at 17:13
The general idea is that you want to recover the modulating signal with as little distortion as possible. There are two sources of distortion: the "contamination" by the remnants of the carrier signal, and the amplitude and phase changes introduced by the R-C filter itself. The minimum overall distortion occurs when these two effects are approximately equal.
I'll leave it to you to demonstrate that this occurs when the R-C cutoff frequency is approximately equal to the geometric mean of the carrier and modulating frequencies.
In practice, the amplitude changes caused by the filter are not really all that important, so it generally makes sense to set the R-C cutoff value to some small multiple of the baseband signal's bandwidth, regardless of the carrier frequency.
