I've followed the directions found here but after the step where I extract the netlists, when I export to PCB it gives the following error.
Error reading the nets from CAMtastic ! (C:\Build\platform_edp\CAMTASTIC\Source Code\Dlls\CAMUtils\ExportCAMToPCB.pas, line 296) at 29C46048.
CAMTASTIC.DLL, Base Address: 29830000.
Exception Occurred In
ExportToPCB
This is a single layer import.
Here is what I have setup:
After working with this for over a year I've found a couple ways of achieving this.
First, working with DXF files is superior. I usually can import those directly into the pcb editor. If I can't, I import them into the cam editor, then export them to another DXF file, then import them into the pcb editor.
If I only have Cam files, The one thing I missed was this
Within Tables > NC tools I needed to specify a drill size. Often times that fixed my problem.
  • \$\begingroup\$ Good on you for following up \$\endgroup\$
    – efox29
    Nov 11, 2015 at 4:07
