circuit symbol
Does anyone know what this circuit symbol is? My guess is that it's a surge protector but I'm not sure
Context
    \$\begingroup\$ It would help to show the context this symbol is in. \$\endgroup\$ Sep 24, 2014 at 18:32
  • \$\begingroup\$ Just edited to add context \$\endgroup\$ Sep 24, 2014 at 18:36
  • \$\begingroup\$ @SivaDotRender The context image is not visible. \$\endgroup\$
    – Karlo
    Mar 2, 2017 at 15:42
According to Edraw: Standard Process Flow Diagram Symbols and Their Usage, it is the symbol for a pump.
  • \$\begingroup\$ It turns out that the SPKx5 referenced in the image is a gas valve. So either this is the symbol for the valve itself, or some kind of ancillary pump associated with the valve's application. \$\endgroup\$
    – Dan
    Sep 24, 2014 at 19:18
  • \$\begingroup\$ I did some research and yes you are correct. This is the pump that pumps oil into a piston in order to open the valve. \$\endgroup\$ Sep 24, 2014 at 20:24
Looks like a general pump symbol to me.
ref: http://processprinciples.com/2012/07/autocad-pid-pump-symbols/
