I am reading about mesh and node equations, and the book says that the voltage between \$V_1\$ and \$V_2\$ can be expressed as: $$ 10\cdot I = V_2 - V_1 $$
How is this possible? And is there a general formula for expressing the voltage across the dependent current source? It says that the controlling current is expressed as: $$ I = \dfrac{V_s - V_1}{R_1} $$
(which I do understand as per ohm's law). But for the dependent source, there is no resistance. I know if you are using mesh analysis, you can assign an arbitrary resistance, say Ro, which will factor out of both mesh equations that contain a current source and it is therefore not an issue.
Also, if I applied KCL to the supernode, would it look like:
$$ I = \dfrac{V_1}{Z_1} + \dfrac{V_2}{Z_2} $$
