Not sure if this is off topic. I have an old ipod dock with a 30 pin male connect and I want to switch it out to a male micro usb. So that I can use the dock. I don't want to use an adapter as I want it to look natural.
I was simply going to rewire old connector to the micro usb.
Ipod Dock pinouts I have found the pinouts for both. http://pinouts.ru/PortableDevices/ipod_pinout.shtml
Micro usb.
http://pinouts.ru/PortableDevices/mini-USB_pinout.shtml
It looks like I can simply connect up the 16, 23, 25 and 27 on the ipod connector to 4, 3,2,1 respectively on the micro usb side.
Just wanna make sure before I do anything.
You can do that, since it's USB which is standard protocol.
But you can't use speaker because dock's speaker is connected to pin 3 & 4.
If you want to use it, you can solder an audio cable to pin 2, 3 & 4.
  • \$\begingroup\$ It really sucks that you can not use the pins that are already there. \$\endgroup\$ Oct 22, 2014 at 17:29
