I need to solve the task shown on the picture. task
The first part is to calculate the temperature (in °C) from the NTC when Uv = 2V is. This means Iv is infinite.
The given Values are: Uq = 12V, R1 = 100Ohm, R2 = 200Ohm, R3 = 300Ohm
NTC: Rn = 1kOhm, b = 2000Kelvin, Tn = 293K
I tried using the formula: Uv = Uq((R2/(R1+R2)) - (R3/(R3+NTC))) and got 600Ohm for the NTC. After using it in the forumla for calculating an NTC I got only 81.85 degrees Celsius.
Can someone help me?
Assuming E3 is greater than E2, here's another way to do it:
Leaving you do to the work but here's a clue where you have gone wrong.
Why did you subtract the resistance of the NTC.?
                                " R3/(R3-NTC) "
The resistance is POSITIVE it is the change in resistance (dR/dT) that is a negative slope.
ADDITIONAL EDIT:
Note the direction of the voltage source. Their will be 4V across R1 and as point A is more positive than point B by 2V that means the voltage across the thermistor will be 2V.
The thermistor and R3 also form a voltage divider so 2V must also equal 12Rx/(R3 + Rx). Gathering terms and simplifying this gives a value of 60 ohms for the thermistor not 600.
  • \$\begingroup\$ Ah, I made a mistake there. It should be +. \$\endgroup\$ – Pascal Oct 2 '14 at 14:12
  • \$\begingroup\$ But I did not make this mistake in my calculation. So I still have no clue how to solve this \$\endgroup\$ – Pascal Oct 2 '14 at 14:25
