I've been wondering. How hard is it to craft a (digital) watch from scratch?
I'm currently thinking that (with a lot of assumptions) you can buy/import quartz chips or something like that from overseas, and then after putting them on a case, stick them to some circuits, batteries, some LCD display etc.
So yeah, what other considerations could there be, besides manufacturing (cases, straps etc)?
disclaimer: I'm a complete newbie when it comes to electronics, so you probably cringed just by reading that. I'm just curious about this because after trying to shop for a good watch, it seems that there's almost too many choices, and I can't help but wonder how hard is it to get to the watchmaking business.
  • \$\begingroup\$ You might like to study the µWatch project. \$\endgroup\$ – Kevin Reid May 24 '11 at 23:28
  • \$\begingroup\$ @Kevin Reid: I hear Paul Pounds plans to release the design files for his LED Pocketwatch, as µWatch has already done. \$\endgroup\$ – davidcary Jun 19 '11 at 18:15
6
The quartz crystal should be the least of your problems. You can find them in miniature dimensions (2mm diameter x 6mm length) at any distributor. You may have some trouble to find the LCD, though. Microcontrollers in small packages are readily available, but they usually don't have enough I/O pins to control the LCD + some buttons. In common watches you'll see that they solved this by bonding the die (with sufficient I/Os) directly to the PCB. Standard components are never used for the battery holder and the push buttons, because they wouldn't fit. Instead, custom made metal metal strips are used.
Frankly I think this will be a difficult to do. If you really want to build a clock I'd suggest to make it a table top clock.
The main difference between you and the watchmakers business is that you want to build 1 (one) watch, while they build them in large quantities, which allows them to use custom components at a low cost.
Not at all difficult - the most expensive part would be making a nice case. For minimum cost you'd be constrained to a small selection of off-the-shelf LCDs (which also constrains choice of case), but if you;re serious you can get a batch of small custom-design LCDs for something like $1000-2000 for several hundred units including tooling.
What about the TI Chronos?1 I've considered buying one for its large display, which would be very nerdy but also very practical with my poor eyes. It's relatively inexpensive, too.
