I have a STM32F207ZG-SK board, and I want to configure pin B0 and A6 to read analog values from another board.
Did I do the setup for pin B0 and A6 correctly? I checked to see if it has ADC and it does, so I just changed certain areas of the code. The code was originally for Pin A0 and C5.
B0 --> ADC12_IN6 so does that mean that its for both ADC1 or ADC2 and that the channel is 6? Information on the ADCXX_INYY can be found here, but it doesn't say what it means.
So I changed
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure); --> changed to GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; --> changed to GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_Init(GPIOC, &GPIO_InitStructure); --> changed to GPIO_Init(GPIOA, &GPIO_InitStructure);
and
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2| RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOE, ENABLE);
--> changed to
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2| RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOE, ENABLE);
Here is the code that I have so far, but for some strange reason its only reading 0's, when it is suppose to read 0.9V.
Information on the configuration of the ADC can be found here.
#define ADC_CCR_ADDRESS   ((uint32_t)0x40012308);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2 |RCC_APB2Periph_ADC1 , ENABLE);
DMA_StructInit(&DMA_InitStructure);
DMA_DeInit(DMA2_Stream0);  //Set DMA registers to default values
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC_CCR_ADDRESS; //Source address*/
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&Adcdata; //Destination address*/
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = 2; //Buffer size
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //source size - 16bit
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; // destination size = 16b
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &DMA_InitStructure); //Initialize the DMA
DMA_Cmd(DMA2_Stream0, ENABLE);
/*ADC Init*/
// ADC_CommonStructInit(&ADC_CommonInitStruct);
// ADC_CommonInit(&ADC_CommonInitStruct);
/*ADC2 configuration*/
ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_RegSimult;
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
// ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_6Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
//ADC_CommonInit(&ADC_CommonInitStructure);
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
// ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 1; /* parallel so it is doing one conversion for one channel and one conversion for the other ADC channel*/
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_56Cycles);
// ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
// ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_InitStructure.ADC_NbrOfConversion = 1; //parallel ADC's for both channels. This is for each one
ADC_Init(ADC2, &ADC_InitStructure);
/*ADC2 regular TRIMER_CHANNEL configuration*/
ADC_RegularChannelConfig(ADC2, ADC_Channel_15, 1, ADC_SampleTime_56Cycles);
// ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 1, ADC_SampleTime_56Cycles);
ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
// ADC_DMARequestAfterLastTransferCmd(ADC2, ENABLE);
// ADC_ExternalTrigConvCmd(ADC2, ENABLE);
/* Enable ADC2 */
ADC_Cmd(ADC1, ENABLE);
ADC_Cmd(ADC2, ENABLE);
ADC_DMACmd(ADC1, ENABLE);
ADC_SoftwareStartConv(ADC1);
Adc1=(((float)Adcdata[0]) * 3.3)/4096;  //voltage value
Adc2=(((float)Adcdata[1]) * 3.3)/4096;  //voltage
  • \$\begingroup\$ What is the question? \$\endgroup\$
    – JYelton
    Oct 4, 2014 at 19:20
  • \$\begingroup\$ Did I do the setup for pin B0 and A6 correctly? I checked to see if it has ADC and it does, so I just changed this area of the code: GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA, &GPIO_InitStructure); \$\endgroup\$
    – Luxii
    Oct 4, 2014 at 19:22
    \$\begingroup\$ Please add that to the question using the edit option. \$\endgroup\$
    – JYelton
    Oct 4, 2014 at 19:23
  • \$\begingroup\$ Done. Thanks for guiding me to writing the right question \$\endgroup\$
    – Luxii
    Oct 4, 2014 at 19:35
So it turns out that ADCXX_INYY, means that XX - the type of ADC's that you can configure to (i.e. 12 = can configure to ADC1 or ADC2). YY represents that GPIO channel where you can configure ADC.
Also, you need to do ADC_CommonInitStructure only once.
Here is the new and improved version of the code for further convenience.
static volatile Int32U TimingDelay;
int i;
__IO Int16U Adcdata[3];
__IO float Adc1=0;
float Adc1_avg=0;
__IO float Adc2=0;
float Adc2_avg=0;
__IO float Adc3=0;
float Adc3_avg=0;
void RCC_Configuration(void)
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOE, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 | RCC_APB2Periph_ADC3, ENABLE);
void DelayResolution100us(Int32U Dly)
  TimingDelay = Dly;
  while(TimingDelay != 0);
  * @brief  Decrements the TimingDelay variable.
  * @param  None
  * @retval None
void TimingDelay_Decrement(void)
  if (TimingDelay != 0x00)
    TimingDelay--;
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  /* ADC Channel  8 -> PB0  ADC12_IN8
     ADC Channel  15 -> PC5 ADC12_IN15
     ADC Channel  0 -> PA0 ADC123_IN0
void ADC_Configuration(void)
  ADC_DeInit();
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  ADC_InitTypeDef ADC_InitStructure;
  /* ADC Common Init - COMMON - Do it once, do it first */
  ADC_CommonInitStructure.ADC_Mode = ADC_TripleMode_RegSimult;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1; // 2 half-words one by one, 1 then 2 then 3
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_6Cycles; //6 or 5?
  ADC_InitStructure.ADC_ScanConvMode = DISABLE; // 1 Channel - why is it DISABLE?
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; // Continuous Conversions
  //ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_TRGO; // Ignored - why include it if ignored?
  ADC_Init(ADC2, &ADC_InitStructure); // Mirror on ADC2
  ADC_Init(ADC3, &ADC_InitStructure); // Mirror on ADC3
  /* ADC3 regular channel 8 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_56Cycles); // PB0
  /* ADC2 regular channel 5 configuration */
  ADC_RegularChannelConfig(ADC2, ADC_Channel_15, 1, ADC_SampleTime_56Cycles); // PC5
  /* ADC3 regular channel 0 configuration */
  ADC_RegularChannelConfig(ADC3, ADC_Channel_0, 1, ADC_SampleTime_56Cycles); // PA0
  /* Enable DMA request after last transfer (Multi-ADC mode)  */
  /* Enable ADC1 */
  /* Enable ADC2 */
  /* Enable ADC3 */
  ADC_Cmd(ADC3, ENABLE);
  ADC_DMACmd(ADC1, ENABLE); //enable ADC1 DMA since ADC1 is the master
static void DMA_Configuration(void)
  DMA_InitTypeDef DMA_InitStructure;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)0x40012308; // CDR_ADDRESS; Packed ADC1, ADC2
  DMA_InitStructure.DMA_BufferSize = 3; // Count of 16-bit words
  /* DMA2_Stream0 enable */
int main(void)
  ENTR_CRT_SECTION();
  if(SysTick_Config(SystemCoreClock/10000))
    while (1);
  EXT_CRT_SECTION();
  RCC_Configuration();
  GPIO_Configuration();
  ADC_Configuration();
  DMA_Configuration();
  /* Start ADC1 Software Conversion */
  /*Turn on Backlight*/
  GLCD_Backlight(BACKLIGHT_ON);
  GLCD_SetFont(&Terminal_9_12_6,0x000F00,0x00FF0);
  GLCD_SetWindow(10,116,131,131);
  /*-------------------Display Readings-----------------------------------------*/
  GLCD_PowerUpInit((pInt8U)IAR_Logo.pPicStream);
  while(1){
    /***** Compute Gain and Phase ****/
        Adc3_avg = 0;
        Adc2_avg = 0;
        Adc1_avg = 0;
        DelayResolution100us(10000);
        for(i=1;i<=20;i++)
          Adc1_avg = Adc1_avg + Adc1; //average gain
            //   Adc2con = (Adcdata[1] & 0x0FFF);
          Adc2_avg = Adc2_avg + Adc2;//average phase
          //   Adc3con = (Adcdata[1] & 0x0FFF);
          Adc3=(((float)Adcdata[2]) * 3.3)/4096;  //voltage
          Adc3_avg = Adc3_avg + Adc3;//average phase
        Adc1_avg = Adc1_avg/20;
        Adc2_avg = Adc2_avg/20;
        Adc3_avg = Adc3_avg/20;
        //Write to LCD
        GLCD_TextSetPos(0,0);
        GLCD_print("G:%.02f", Adc3_avg);
        GLCD_TextSetPos(7,0);
        GLCD_print("P1:%.02f", Adc2_avg);
        GLCD_TextSetPos(17,0);
        GLCD_print("P2:%.02f", Adc1_avg);
  }; // Don't want to exit
