I am trying to understand the frequency response curve of various types of filters (Butterworth, Chebyshev etc).
The curves are shown here for reference : enter image description here
One thing I do not understand is what do the ripples in passband show.
The curve is clearly Gain vs Frequency. So all the ripples show is that the gain of filter varies slightly with the frequencies in the passband. How is that suppose to create a problem ? We will only get an output which is varying in amplitude. It would have created a problem had we been getting a distorted output, which was possible only when the filters introduced a distortion, and I dont think it has anything to do with gain at different frequencies.
Based on above assumption, why would one not simply opt for a filter with steepest rolloff (elliptic in the figure) , without worrying about the ripples in passband ?
Edit :
It seems I am not able to properly express my doubt. Here is another attempt :
Many articles on filter design mention "Butterworth response is maximally flat, while others like Chebyshev and elliptic have ripples". My query is what has this "maximally flatness " or presence / absence of ripples anything to do (if at all) with the purity of applied signal. Purity in the sense, I apply a signal of a particular frequency, and I get an exact replica back. Will the situation be different in case of different filter types, ie , will I get some spread out or mis-shaped waveform if the filter response has ripples?
If that is the case, then how can this be inferred from the frequency response curve alone , because frequency response curves only show that the gain of the filter varies with frequency ; they dont speak anything about what the shape of wave will become if the curve has ripples or not.
My doubt arises because the texts generally differentiate between various filter responses by citing something like "Chebyshev response differs from butterworth because it has ripples in the passband".
Additionally, if all of the above is not true, ie ripples bear no relation to altering the shape of input, then what do they signify ? ( One of the users made and attempt at that. If possible, please extend or elaborate a little)
I am talking of only a simple situation with just one input (let alone many inputs). Maybe someone is kind enough to point me to some resources which show response of these filters to a single sine input.
Thank You
  • \$\begingroup\$ If you care about group delay or phase shift, it makes a difference. \$\endgroup\$
    – MarkU
    Commented Oct 5, 2014 at 5:19
  • \$\begingroup\$ @MarkU . How does that relate to these curves. Many articles and books refer to these curve and say "Butterworth is maximally flat" or "Chebyshev has ripples". What do these curves have anything to do with distortion ? Phase response curves are an entirely different deal. I am specific to these curves. \$\endgroup\$ Commented Oct 5, 2014 at 5:28
    \$\begingroup\$ But that's an important design trade-off. Butterworth gives the least gain ripple in passband and stopband AND has lowest phase distortion / group delay, though higher-order filtering is needed to achieve a decent cutoff slope. In an application requiring low component count but where neither group delay nor passband ripple is important, then Chebyshev or elliptic wins. It all depends on what signal characteristics are important. \$\endgroup\$
    – MarkU
    Commented Oct 5, 2014 at 5:51
    \$\begingroup\$ Bode plots show both gain and phase for good reason. Looking at only the gain response without considering phase response, you're missing an important part of the system performance. \$\endgroup\$
    – MarkU
    Commented Oct 5, 2014 at 5:53
  • \$\begingroup\$ That simply means that this curve by itself is not much of a use. Its useful only when combined with other curves. Almost every article and book on filters which I have read convey the info "Frequency response of butterworth is maximally flat. Hence it has least distortion." and likewise. This gives an impression that somehow the amplitude or gain is related to distortion, which I hope is not so. \$\endgroup\$ Commented Oct 5, 2014 at 5:59
The ripples in the pass band are typically an unwanted side-effect of producing a higher order filter that has a steep roll-off. If the ripples are too big and I'm using the filter for an audio application I'll probably hear the shape of those ripples in the music so yes, mainly they are undesireable.
The ripples do usually show something - they indicate to me that the higher/steeper filters are probably constructed physically (and mathematically) from a series of 2nd order filters.
  • \$\begingroup\$ You are not getting the point. How can something which is related to amplitude possibly show distortion ? The frequency response curve is a measure of Gain (amplitude ) vs freq, while distortion is something related to phase shifts I believe. So ripples in freq response curve should only result in varying amplitudes, which will be audible as louder or less louder depending on freq. Then why is it related to distortion ? \$\endgroup\$ Commented Oct 5, 2014 at 9:55
  • \$\begingroup\$ I believe I've answered your question (as I read it) and I think you are possibly using the term "distortion" as meaning adding harmonics that were not present in the original signal (pre-filtered). A filter will change the amplitudes of harmonics but won't generate new ones (this is still referred to as distortion but aint as bad as "adding new harmonics". Maybe I'm still misunderstanding your question. \$\endgroup\$
    Commented Oct 5, 2014 at 10:24
  • \$\begingroup\$ Take a look at this link : simonbramble.co.uk/techarticles/active_filters/… . The author here mentions, under types of filters that, a chebyshev filter has ripples, hence its no use in audio system. But why ? Also at the bottom, look at the last simulation. The response of 9th order chebyshev has such steep rolloff. Why would anyone not prefer such good cutoff and instead go for Butterworth, simply because it has no ripples ? In short, has ripples in passband anything to do with distortion( altering shape) or am i misunderstanding it ? \$\endgroup\$ Commented Oct 5, 2014 at 11:06
  • \$\begingroup\$ A filter that has ripple in the passband is acceptable for audio providing the ripple is small enough. I reckon 1dB ripple will hardly be noticed by anyone listening to a piece of music. When it comes to filtering instrumentation signals then ripple is going to be a problem and so is the increased time delay of higher order filters. It's not a black and white thing - I design "instrumentation" filters that go in front of ADCs and behind DACs and +/-0.2dB is acceptable. Providing no new significant frequency artefacts are introduced any filter can suit any application within reason. \$\endgroup\$
    Commented Oct 5, 2014 at 11:30
    \$\begingroup\$ That is how I interpret things, yes. \$\endgroup\$
    Commented Oct 8, 2014 at 9:43
Butterworth gives the least gain ripple in passband and stopband, and has lowest phase distortion / group delay -- though higher-order filtering is needed to achieve a decent cutoff slope. If your application cares about group delay or phase shift, then Butterworth gives the least distortion. Unfortunately, to achieve both zero passband ripple and very steep cutoff stopband transition at the same time, then a very high-order Butterworth filter would be required. Near-ideal performance usually has a high cost -- in this case, a higher-order filter requires more components and thus more money and board layout space.
Chebyshev or elliptic improves the cutoff transition, making a very steep cutoff for comparable order. Higher-order filters usually require more components, so this translates directly to saving money and board layout space. However the real cost is that these types of filters require accepting some level of ripple in the passband and stopband (and the phase response is not so linear as Butterworth). There is some design flexibility, you can trade off how much gain ripple is acceptable.
Passband ripple does indicate that there will be some level of distortion in the signal -- the question is whether the level of distortion is acceptable. If maximum passband ripple is 0.1dB and signal-to-noise ratio is good, the ripple may not make a difference. But if zero passband ripple is required, then you need a Butterworth filter.
In an application requiring least distortion, Butterworth wins. In an application requiring low component count but where neither group delay nor passband ripple is important, then Chebyshev or elliptic wins. It all depends on what signal characteristics are important.
Yes, the waveform will be mis-shaped if the filter response has ripples. The amount of distortion depends on the amount of ripple in the frequency response. See the image below which show the distortion in waveform.
Distortion in signal due to non-flat frequency response of the filter
The plot shows output waveforms for 3 different filters with differing amount of ripple in the passband. You can clearly see that the blue signal is significantly different from the other two. Filter design involves a tradeoff between the number of components and flatness of the response.
In general the list below gives filters in decreasing order of component count (and decreasing flatness of frequency response) for some given frequency response specifications:
  1. Butterworth filter
  2. Chebychev filter
  3. Elliptic filter
Note: The outputs shown in the figure above are artificial. In general you would never use a filter with a frequency response like the blue one for lowpass filtering.
