When dealing with BJTs in an approximate large signal analysis, Vbe is often chosen to be 0.7 Volts (Given the component is operating in active mode). My question is: Is it possible to do the same for MOSFETs?
I'm asking this because I'd like to find an approximate expression for the output current in the following current mirror setup:
For the BJT case, I often saw the output current being approximated by (Vcc-0.7/R) so I was wondering whether a similar approach would be valid for the MOSFET structure.
