How do I write an ISR greater than 8 bytes which is triggered by INT0?
    \$\begingroup\$ You place a jump instruction at the address of the interrupt handler, which then allows the actual handler code to be placed anywhere in memory where there's enough room for it. \$\endgroup\$
    – Dave Tweed
    Oct 5, 2014 at 15:02
  • \$\begingroup\$ ORG 0003H ; LJMP START; RETI like this? \$\endgroup\$
    – user258699
    Oct 5, 2014 at 15:14
    \$\begingroup\$ What is that RETI for at that place? There is no return from a jump, so the RETI must be at the end of the code that you jump to. \$\endgroup\$ Oct 5, 2014 at 15:21
Your code jumps to the ISR which ends in a RETI:
    org 0003H
    jmp isr
isr:
    ; any instruction you need
    reti
If you program in C, this will be handled for you automatically. For example, Keil-C51 places ISRs right at the start address if there is enough room, or jumps to it if not.
