I hear that there are at least two kinds of circuits in modern audio amplifiers solely for the purpose of protecting the speakers against excessive loads on powering on and off.
Particular function of these circuits is delaying the connecting of speakers so long that there is reasonable probability of the amplifier to have become stabilised on powering on; and disconnecting the speakers prior to powering the amp off.
The effect is that neither on powering on or on powering the amp off the speakers produce a loud pop or boom, as the simpler older amps used to do.
My question is how exactly are these circuits called and what is their typical setup.
Background: I have two Behringer EPQ304's, and one of them always pops on powering off, and my googling produced little insight so far. English is my second language, so perhaps I've missed the proper names. But I'm interested in the design as well.
  • \$\begingroup\$ I think you're talking about an "inrush limiter". \$\endgroup\$ Oct 7, 2014 at 21:24
  • \$\begingroup\$ I know nothing about audio and speakers, but it sounds like an amp problem. (NPI) \$\endgroup\$ Oct 7, 2014 at 23:29
  • \$\begingroup\$ @GeorgeHerold: Yes, it literally sounds like it. The amp works fine, I just need to fix the thump sound on powering off. \$\endgroup\$
    – Pavel
    Oct 8, 2014 at 6:33
These circuits are often called "soft-start" or "pop-suppression" or "speaker-protection". There are probably other names but I don't think there's a standard.
A popular protection circuit uses relays to connect the amplifier output to the speaker connector. There are several ways to control the relay:
  • Keep the relay disconnected for x seconds after power-on, giving the amplifier time to settle, then close the relay to connect the speaker. This alone would eliminate your pop at power-on. You can also disconnect the speaker when the power is turned off (but before the amplifier power supply drops too low to work) to eliminate a thump at turn-off.
  • A more sophisticated relay-based protection circuit would low-pass filter the output signal to look for any DC component and disconnect the speaker if it detects it. DC can burn out any non-AC-coupled speaker (like a woofer), and audio amps don't need to go below ~20Hz, so any DC component would indicate a fault condition and the relay would open to disconnect/protect the speaker. Typically DC faults are caused by failed transistors or the collapse of one of the supply rails. Depending on the design, this could be used WITH the above delayed-solution or instead of it (since the thump during power-on is usually a low-frequency transient that the DC detector could catch).
  • Many amplifier designs also monitor the temperature of the output transistors and disconnect the speakers if they go above the max temp the design allows.
A lot of audiophiles believe relays color the sound, and the resistance of relay contacts can degrade over time, so some amp designers add solid-state circuits that remove the biasing from the output transistors to effectively disconnect the amp, and provide a soft-start function during power-on. This might not provide quite as robust protection as a relay, but it's a good solution.
If your goal is to fix the amp with the turn-off thump, there are two options:
  1. Add a relay and a circuit that detects when the power supply starts to fall that disconnects the speaker.
  2. Since one of your amps doesn't have the problem, try to find out what's different between the amps. If you can find and post a schematic I could tell you what to probe for - we might be able to troubleshoot it with just a voltmeter... It's possible that the noisy amp has a protection circuit that's not working correctly, but it's also possible that the quiet amp just happens to be more "balanced" during power-down (the supplies come down more symmetrically or in a way that turns off the correct output transistor earlier)...
  • \$\begingroup\$ I wonder if the amp has a dual power supply, but one rail capacitors are failing causing unequal power-on/off voltage ramping. Especially if he has an identical model that doesn't exhibit the problem. \$\endgroup\$ Jan 20 at 23:43
