I need to take a 12MHz AC sine wave, from around 3.3V - 10V @ 10uA, output 50V, @ 1A (or more).
I have the signal generator for signal input, but I am not certain what I need for a circuit to step that up to the appropriate power level. And what if any isolation and OCPD I might need to protect my control circuit.
Should I use a toroidal transformer? Something else? Can someone point me to a specific device or module that I can buy?
    \$\begingroup\$ What you are looking for is an "RF power amplifier", and they're commonly available. You need one that's rated for at least 50W (50 Vrms * 1 Arms). \$\endgroup\$
    – Dave Tweed
    Oct 10, 2014 at 14:05
  • \$\begingroup\$ I found parts, and I submitted a pair of designs for approval. Thanks Dave, for helping with what words to look for. \$\endgroup\$
    – j0h
    Oct 10, 2014 at 14:29
This is not possible, as you view it. Conservation of energy
IN: 10V*10uA == 100uW
OUT: 50*1A = 50W.
You will need a power amplifier to take the small-signal AC to increase the power capability
  • \$\begingroup\$ yeah, which one? or should I amplify that signal, then step it up? I need parts. Please Advise. I can add supplemental power no problem. \$\endgroup\$
    – j0h
    Oct 10, 2014 at 12:05
    \$\begingroup\$ you would need an amp that could source >5A at 12MHz. A classAB could do it if you could manage the losses. \$\endgroup\$
    – user16222
    Oct 10, 2014 at 12:10
