8
What is the difference between >> and >>> in verilog/system verilog? I know that == tests for only 1 and 0, while === tests for 1, 0, X, Z. So how is that similar to the shift operator?
It is not similar to ==/===, if the left hand operand is signed then >>> performs sign extension.
reg signed [9:0] b = 10'sb11_0101_0101;
reg signed [9:0] a_signed;
reg        [9:0] a_unsigned;
always_comb begin
  a_signed   = b >>> 2;
  a_unsigned = b >>  2;
end
Result:
#a_signed   1111010101
#a_unsigned 0011010101
Example on EDA Playground.
    \$\begingroup\$ Wow, that is exactly the opposite of the meanings of the Java >> and >>> operators... wicked. \$\endgroup\$ – Colin D Bennett Oct 11 '14 at 7:23
    \$\begingroup\$ Verilog was 10 years before Java. :P \$\endgroup\$ – dave_59 Oct 11 '14 at 15:49
    \$\begingroup\$ @dave_59, but signed values (aside from the 32-bit integer type) and the arithmetic shift operators were only introduced to Verilog in Verilog-2001. \$\endgroup\$ – The Photon Jan 19 at 22:15
    \$\begingroup\$ Verilog already had >> to mean logical shift in 1985 (taken from Pascal, which is from 1970). So it had to use >>> for arithmetic shift. \$\endgroup\$ – dave_59 Jan 20 at 2:11
8
According to IEEE1800-2012 >> is a binary logical shift, while >>> is a binary arithmetic shift.
Basically, arithmetic shift uses context to determine the fill bits, so:
  • arithmetic right shift (>>>) - shift right specified number of bits, fill with value of sign bit if expression is signed, otherwise fill with zero,
  • arithmetic left shift (<<<) - shift left specified number of bits, fill with zero.
On the other hand, logical shift (<<, >>) always fill the vacated bit positions with zeroes.
For example:
a = 5'b10100;
b = a <<< 2; //b == 5'b10000
c = a >>> 2; //c == 5'b11101, 'cause sign bit was `1`
d = a <<  2; //d == 5'b10000
e = a >>  2; //e == 5'b00101
