I'm doing little lab exercise with an RL circuit. I need to check if I did this analysis right, because the numbers I got and the numbers that should theoretically be there are so far off, I figured I had to be doing something wrong.
We have the following circuit:
And we want to measure the voltage across AB and build a bode plot, and ID what kind of filter it is.
So I get a bunch of values for the voltage. No problem, I plot them and the shape looks like a good Bode plot. I even marked the cutoff frequency and it looked like it was in the right place.
But when I tried deriving a theoretical Bode plot the curve always looked off -- way off. It was either too far to the right (the inflection point was off by orders of magnitude) or too high or too low. So I want to make sure I derived the response function correctly. If yes, then fine; I can say that it's off because the resistor and inductor aren't perfect. (One would expect that). But I am really struggling here.
So, here's what I did: the response function on this circuit will be $$H(\omega)=\frac{V_{out}}{V_{in}}$$
\$V_{in}\$ is easy enough since I set the RMS at 1 V. But mathematically it should be (Ohm's law) V=IR and the total impedance of the circuit at a given frequency (using f not omega) is \$R+ i\frac{f}{2\pi}L)\$. That means \$I = \frac{V_{in}}{R+ i\frac{f}{2\pi}L}=\frac{2\pi V_{in}}{2\pi R+ ifL}\$. That should mean that $$V_{out} = V_{AB} = \frac{V_{in}fL}{2\pi R+ ifL}$$ and my response function is $$H(f) = \frac{fL}{2\pi R+ ifL}$$
I need to convert this to a real number and a magnitude, so I did this:
$$|H(f)|^2 = \frac{(fL)^2}{(2\pi R+ ifL)(2\pi R- ifL)}=\frac{(fL)^2}{(2\pi R)^2+ (fL)^2}\rightarrow |H(f)| = \frac{(fL)}{\sqrt{(2\pi R)^2+ (fL)^2}}$$
But this does not produce anything like the values I got. The Bode plot goes up to a certain value and flattens out, as though this were a low pass and not a high pass filter.
Now, if I were using just R in the numerator of my transfer function it looks the right shape, but not in the right place.
Her'es the values in millivolts I got for \$V_{AB}\$ at various multiples of fc (cutoff frequency) in Hz. Fc = 4289 Hz.
428.9: 68.3
2144.5: 64.8
4289: 52.6
8578: 34.7
17156: 1.2
Anyhow I am just trying to suss out what I did wrong here, if anything.
