I can't understand the difference between a magnetic field sensor and a hall effect sensor, to me are both the same.
I have a voltage detector pen that I can use when I troubleshoot my house I believe it detects the electric field (magnetic), but that's it.
  1. If I wanted to make a circuit with a sensor that knows when any kind of metallic object is nearby, which kind of sensor would I have to use?
  2. What kind of sensor do supermarkets use?
  3. How can I increase the detection distance of such sensors?
  4. How could I detect (for example) a car passing by the street with my sensor?
  • \$\begingroup\$ When you get some time, take a look at your previous questions and how they were edited. Thanks! \$\endgroup\$
    – JYelton
    Oct 15, 2014 at 18:35
  • \$\begingroup\$ A hall effect sensor is one type of magnetic field sensor. Others include MEMS Lorentz-force sensors, flux gates, and many more. \$\endgroup\$ Oct 15, 2014 at 18:52
  • \$\begingroup\$ Wow, that's a splattering of a number of questions. First pick some one thing you are interested in. Then research it, and try to figure it out. Maybe do some measurements. (There's nothing like real data.) Then when you are still confused about something, come and ask. \$\endgroup\$ Oct 15, 2014 at 23:08
1) If i wanted to make a circuit with a sensor that knows when any kind of metallic object is nearby, which kind of sensor would i have to use ?
You need to use a metal detector to detect a metallic object i.e. an object that can pass current or modify a magnetic field it comes into vicinity of. A metal detector generates an alternating magnetic field which will induce eddy currents into a metallic object. These eddy currents remove energy from the magnetic field and this is detectable. Non conducting materials like ferrite are also detectable because of the permeability of the material modifies the applied magnetic field in a different way to induced eddy currents. Metal detectors.
2) What kind of sensor do supermarkets use?
If you are talking about shop products that have a tag read this. These generally use a 13.56MHz magnetic field and operate very similarly to a metal detector.
3) how can i increase the detection distance of such sensors?
This can be done on metal detectors by spacing the transmit and receive coils out further and piling more electrical energy into the transmit coil. On RFID tags it's harder because the tag (the portable part) has to modify the imposed magnetic field in order to make itself detectable and with a larger incident field and coils further apart it rapidly becomes a really difficult job just to double the distance. Mag field reduces as a cube law so doubling the distance means 8 times less incident field and 8 times less received signal coming back. Net effect is a reduction in received signal relative to the incident signal of 64 : 1 (simplified math alert!). That's a big deal!!
4) how could i detect (for example) a car passing by the street with my sensor ?
Most car sensors are buried in the road and pretty much operate on the principles of metal detection.
