For the MIPS insturction Load Word I have got the following Datapath:
How does the datapath for the Instruction Load Upper Immediate looks like?
    \$\begingroup\$ Pretty much the same, but with no reading from Memory(data)? The value for LUI is encoded as the lower 16-bits of the 32-bit opcode. \$\endgroup\$ – Majenko Oct 15 '14 at 23:28
I had these pictures sitting around except for the red lines.
The two instructions differ in semantics:
LUI and LW instructions
$t is the destination register, $i is an immediate value.
LUI:
LUI data path
LW:
LW data path
The images are all links to their full size versions.
In a real implementation the muxes to the ALU could likely produce 0 and 1 constants.
And along the bottom of those pipeline diagrams the $t should actually be t, the pointer to the target or destination register.
