Trying to solve this problem where direct cache would outperform associative:
Propose you have a cache with a line size of L 32-bit words, S number of sets, W ways, and addresses are made up of A bits. Assume that the cache is word addressed, i.e., the low two bits of the address are always 0.
Come up with a sequence of addresses for a MIPS processor for which a direct-mapped cache of size 16 words, line size 4 words, outperforms a fully-associative cache with the same line size, using LRU replacement.
What I've gathered:
  • Direct Mapped Cache means that a block of memory is mapped directly to line of cache
  • MIPS uses Fetch, Decode, Execute, Encode, Memory (this might be irrelevant here)
  • LRU replacement - Oldest Used is replaced
  • Word are least significant bits which represent the address from main memory
    Cache structure:
    Tag   |   Line   |   Word
    Word represents least significant bits
    Tag represents the unique identifier for that
    Size 16 words would be 2^4 bytes
    number of lines would be cache capacity / line size =     ? / 2^4
I'm not sure how to draft this cache. If we have 16 words, 4 per line it would that would mean 4 total rows. I don't expect a full answer but an indication on how to draft the direct mapped cache and come up with a sequence would be greatly appreciated.
UPDATE:
I attached a picture with a cache that has 8 memory addresses mapped to 4 lines. cache map. With this, a sequence of
  1234567824136857
  direct mapped:  MMMMMMMMHHMMHHMM (4 Hits)
  f. associative: MMMMMMMMMMMMMMMM (0 Hits)
However, I can't figure out how many lines there should be (16 words, line size 4 words). How many memory addresses will be mapped to how many lines in the cache? My image has 8 to 4. Do I need 16 addresses mapped to 4 lines in the cache?
Don't get bogged down in irrelevant details about line sizes, CPU architectures, etc. The key question is, what conditions would cause a fully-associative cache to replace a line when a direct-mapped cache would not?
Take a trivial example: A pair of caches that contain just two lines each, and three addresses, A, B and C, that do not fall into the same lines in memory. But let's assume that B and C map to the same line in the direct-mapped cache.
Now, take the addressing sequence A, B, C, A, B, C, A, ...
The fully-associative cache will take a miss on every access, since it always replaces the oldest entry with the new entry.
However, the direct-mapped cache will load A just once, and then only suffer misses on B and C, since neither of those will replace A.
  • \$\begingroup\$ thanks for the explanation, I conceptually understand the mapping much better now. The only thing I'm struggling with is figuring out how many memory addresses should be mapped to how many lines in the cache. I attached a drawing and updated my post. THANKS. \$\endgroup\$
    – John
    Oct 18, 2014 at 17:21
