I am working on a very spotty motor failure (I am not the designer). We have a wound armature which is switched by power MOSFETs. These are driven by a FET totem pole type FET driver. When the driver is off therefore, the gate of the power FET is floating. Yeah, I know. Bad design choice. I'm just cleaning up the mess.
There is a triac and drive circuit controlled by a micro output on the stator side of the motor. When you plug the motor in, the drive line is floating since the micro port is tristated until boot is complete. Since this port line is going into an AND gate and floating, you end up with about 5 cycles of AC on it of sufficient amplitude to fire the gate and this the triac. This puts about 3-5 half cycles of the line on the stator, with peaks of up to 100A depending on source impedance. Yup. Another design error - it should have been pulled down.
Problem - this does not happen often, nor does the power MOSFET failure. Out of hundreds of motors, we have had three fail with power FETs shorted drain and gate to source. Question - I am trying to decide if this series of current spikes (which do induce voltage onto the armature - and the turns ratio is 1:1) is a likely suspect, given the poorly designed power MOSFET circuit. The MOSFETs are right across the armature winding. When the motor fails, it does not fail during run. It seems to fail as soon as you plug it in. My evidence is all circumstantial - I have so far been unable to force a failure. But the massive spike at plugin, the rarity of the failure, and the difficulty of duplicating it seem to point at this. If I'm going down the wrong path, I need to know and know why. This seems like it may damage the FET, but I'm looking for path to failure here that makes sense.
At the moment I am cyling several motors, using a PLC to keep an eye on them. The plan is to cycle until failure, apply design corrections and run again. Unless I get a flash of genius.
