In a new design I would like to use the MAX682. In the datasheet I found this typical operating circuit:
I would like to use it exactly like that except that I'm going to pull /SKIP to GND.
In table 2, I find the recommended values for the capacitors: CIN should be 2.2uF, CX should be 1uF and COUT should be 47uF (tantalum) or 10uF (ceramic).
First of all, why does the needed capacity depend on the type of capacitor? And secondly: from the circuit it looks like I can't use electrolytic capacitors for CIN and CX. Is that correct? Why is it so, because it seems clear that the polarity won't change. I would prefer to use electrolytic capacitors because I have them in stock.
I actually did a quick test myself and used electrolytic capacitors everywhere. In total, the circuit drew about 110mA, while the 5V circuit drew only 2mA. And besides that, the output has about 0.4V AC noise. However, it's not entirely sure that this is just because of the capacitors, because I for example didn't use a very short trace between GND and PGND (pin 1 is top left):
So it really isn't possible. The question remains why.
  • \$\begingroup\$ It might be worthwhile adding 100nF caps in parallel with the elctrolytics to see what happens. Good test BTW! \$\endgroup\$
    Oct 19, 2014 at 15:51
I see three things that are hurting your charge pump circuit.
The capacitors are aluminum electrolytic instead of ceramic, so they have very high dissipation factor and low self-resonant frequency. These charge pumps really do require ceramic capacitors.
Second, they are radial-leaded and axial-leaded capacitors instead of surface-mount. That adds some series inductance, which tends to defeat the capacitance.
Third, the whole thing is built on a white solderless breadboard, which adds even more inductance. You'd be better off using a PCB breakout board (like a Surfboard) and solder capacitors with trimmed short leads, or better yet, surface-mount capacitors.
Not all capacitors are created equal, and not even all ceramic capacitors are created equal. The X7R and X5R types give fairly large capacitance values stable over a good temperature range. The cheaper Y5V, Y5U, and Z5V types can lose a lot of their capacitance over temperature, so sometimes we have to compensate for that loss by using higher nominal starting capacitance. (The NP0 and C0G types are highly stable over temperature, but usually are only available in very low capacitance values.)
Back in the day, ceramic capacitors were only available up to about 10uF, but nowadays there are 100uF ceramic capacitors. So the need for using tantalum and aluminum electrolytics is somewhat diminished; now it's driven by a cost vs performance trade-off.
The self-resonant frequency (SRF) is important in switching circuits, because at frequencies higher than SRF, the capacitor stops behaving like a capacitor and starts behaving like an inductor. Surface-mount ceramic capacitors are usually higher SRF and thus closer to "ideal" capacitors.
Aluminum electrolytic capacitors are great for providing a large amount of capacitance and accepting large inrush current, these are typically seen on power supply inputs. But they don't work well for the "flying capacitor" of a charge pump.
Take a look at MAX619EVKIT http://datasheets.maximintegrated.com/en/ds/MAX619EVKIT.pdf for an example of a good charge pump layout, using surface-mount ceramic capacitors.
Disclosure: I am a Maxim employee and designed the MAX619EVKIT way back when great lizards roamed the earth.
  • \$\begingroup\$ Thank you, I always appreciate authoritative answers very much. The quick test I did on my breadboard was of course not how I would build it for real, that's also why I noted that it's not sure why this circuit was drawing so much more current (it could be because of the design issues as well). Anyway, thanks for your clear and extensive answer. \$\endgroup\$
    – user17592
    Oct 21, 2014 at 18:29
The problem is likely to be because electrolytic caps have high relative ESR compared to ceramics.
At the bottom of page 8 of the data sheet it says: -
All capacitors must maintain a low (<100m Ω) equivalent series resistance (ESR)
Such small values as typically used are not always found in electrolytic types.
