I'm trying to get VGA working on my Altera DE0 board using Verilog, but haven't had much luck. It has the same pins as a normal VGA interface except red, green, and blue are all 4 bits each. Here is the logic I've been trying to use to get a solid color to display:
module solid_color (clk, vga_h_sync, vga_v_sync, R, G, B);
input clk;
output vga_h_sync;
output vga_v_sync;
output [3:0] R;
output [3:0] G;
output [3:0] B;
reg [9:0] CounterX;
reg [8:0] CounterY;
wire CounterXmaxed = (CounterX==767);
always @(posedge clk)
if(CounterXmaxed)
CounterX <= 0;
else
CounterX <= CounterX + 1;
if(CounterXmaxed)
CounterY <= CounterY + 1;
reg vga_HS, vga_VS;
begin
vga_HS <= (CounterX[9:4]==0); // active for 16 clocks
vga_VS <= (CounterY==0); // active for 768 clocks
end
assign vga_h_sync = ~vga_HS;
assign vga_v_sync = ~vga_VS;
assign R = 15;
assign G = 15;
assign B = 15;
endmodule
When I try running it, I just get a message on the monitor saying that this display mode is not supported.
This is adapted from http://www.fpga4fun.com/PongGame.html. However, this version claims to be designed for 640x480 displays whereas my monitor is 1280x1024. Is this the issue? If so, how would I adapt this to fit the increased monitor size? (the clock I'm using is 50 MHz)
EDIT: I added in a clock divider module as follows to change the initial clock signal to 25 MHz:
module divide_clock_by_two(in_clk, out_clk);
input in_clk;
output out_clk;
reg out_clk;
always @(posedge in_clk)
out_clk <= ~out_clk;
endmodule
However, the monitor now just shows a black screen, no message about an incorrect mode.
CounterX==767
toCounterX==1535
andCounterX[9:4]
toCounterX[9:5]
to double the timings, but this did not work. \$\endgroup\$
