The BeagleBone Black is great. You plug in the USB cable to your computer and a DHCP connection is established, allowing you to ssh to the BeagleBone in seconds. Unfortunately the Raspberry Pi takes a bit more, and I am in the process of setting it up. I was able to download the raspbian.img to an SD card using my BeagleBone Black using the dd command through the terminal.
Now I have an SD card that should allow the Raspberry Pi to boot into linux, but I have no HDMI cable or monitor, or keyboard to do this.
As I understand it is possible to reach the Raspberry Pi's command line through serial communication. See here. Typically people are doing this using a USB cable with an FTDI USB-Serial chip embedded in it (sold by Adafruit and others).
Is it possible to connect from the BeagleBone Black to the Raspberry Pi's command line through serial communication (such that I can connect to my BeagleBone Black via ssh from my laptop, and then connect to the Raspberry Pi through serial from the BeagleBone Black)?
As I understand there are only 3 pins required - TxD, RxD, and GND.
Unfortunately I see that the Raspberry Pi uses 3.3V logic, and as I understand the BeagleBone Black uses 5V. This means some sort of level shifter circuit should be used.
With the level shifter circuit in place, would it then be straightforward to establish a serial communication between these two boards?
Or should I go with ethernet to connect them and look into setting up DHCP for communication?
    \$\begingroup\$ Don't the RPi images already have DHCP and Avahi running? \$\endgroup\$ Oct 20, 2014 at 3:24
    \$\begingroup\$ You can mount the raspbian SD card on your PC, make sure /etc/network/interfaces contains auto eth0 and iface eth0 inet dhcp, chroot into it, apt-get install openssh-server, etc. and then it will come up on its own. \$\endgroup\$
    – hobbs
    Oct 20, 2014 at 5:27
    \$\begingroup\$ But yes, you can use the BBB as a serial interface, with a level shifter or a ghetto shifter (no shift on the pi's TX, and a resistor divider on the pi's RX) \$\endgroup\$
    – hobbs
    Oct 20, 2014 at 5:29
The BeagleBone Black has 3.3V logic level signals. Its serial ports are all 3.3V ports. UART0 is tied to the debug header, and is hard coded for the debug log from the BBB. It is not useful for standard communication between two devices.
You have two main options. Luckily, the BBB has multiple UARTs that can be enabled. Turn one of the other UARTs on and connect the appropriate pins from the expansion headers to the RPI. Since the RPI defaults to a UART shell on the serial port, you can ssh into your BBB and then use minicom or similar to talk to the RPI from there.
Alternatively, you can use a USB serial cable on the BBB's USB Host port (or OTG if you needed to). AND you can also do the same on the RPI (so you have two usb to serial cables connected together), but that would require some setup on the RPI, a catch 22.
I don't have enough reputation to comment, but for clarification the BBB uses 3.3v serial as well, so no level shifter is needed.
As to the overall question, yes this should work in a pretty straightforward manner. I know the BBB by default presents a serial terminal on UART0 (/dev/ttyO0) which goes out to the debug port. As long as the raspberry pi does the same it should just work to connect them (swapping rx and tx) and access the serial console. I do not know if this is the default setup for the pi though.
