I'm trying to make a latching power switch based off this schematic (source: EDN) push button latching power circuit
I emulated the circuit in Falstad and everything works like it should (link to simulation).
However, it doesn't work when assembled on a PCB. When I click the button, I see a sudden spike at Vout from 0 to 0.2V and then it quickly settles back to zero. I'm seeing no behavior that is similar to the simulation. I'm now starting to think I selected the wrong MOSFET/Transistor for the job, but I'm not sure which property would effect the circuit.
Here are some more details about my imlementation:
  • Vs - LiPo Battery (3.9 to 4.2 V Nominal)
  • Desired Vout - mirrors +Vs
  • Mosfet - FDN352AP
  • Transistor - MMBT2222A
Any thoughts? This is the first analog circuit I've built (simulated a few), so not really sure where to start looking.
This issue is solved. The circuit was failing due to a faulty isolation diode earlier in the circuit.
|improve this answer|||||
