Many sampled data systems accept a 10 MHz frequency standard. I'm designing a sampled data system, and would like to include the ability to lock to an external clock reference.
I've seen many different outputs, I have one GPS reference that puts out 13 dBm into a 50 ohm load, a distribution amplifier that puts out 1 V p-p into a 50 ohm load, and I'm sure there's many others, so I'm a bit confused as to what inputs I should be able to cope with to make this system versatile.
Is there a standard or a suggested range for a 10 MHz frequency reference input?
Thanks, Ryan
1V (=13dBm at 50Ohm) is fairly standard.
Source: have lots of expensive spectrum analyzers on my desk.
  • \$\begingroup\$ Thanks much, after hunting around a bit more, you're quite right. \$\endgroup\$
    – robot-army
    Nov 2 '15 at 21:27
