I have a simple segmentation system with the following segment table:
Starting Address    Length (bytes)
660                 248
1752                422
222                 198
996                 604
Determine the physical address for the following logical addresses; indiciate segment faults. I know the answers, but I don't understand how they were calculated:
a. 0, 198  --  858
b. 2, 156  --  378
c. 1, 530  --  seg fault
d. 3, 444  --  1440
e. 0, 222  --  882
  • \$\begingroup\$ (1) This looks like a homework. Initial effort not demonstrated. (2) This question doesn't deal with electronics design, as far as I can tell. \$\endgroup\$ Oct 22, 2014 at 2:30
  • 4
    \$\begingroup\$ No, Nick, the answers are known to the poster, it's the concept they are admirably trying to grasp - much better than the reverse case. And this is typically a hardware design problem - an MMU is a part of the processor or board circuitry. In this simple case it consists of a lookup table, a comparator and an adder. \$\endgroup\$ Oct 22, 2014 at 4:10
a) 660 + 198 = 858
b) 222 + 156 = 378
c) 530 > 422
d) 996 + 444 = 1440
e) 660 + 222 = 882
First, you have to check if (offset < segment limit) for problem. If it is, add offset + base address for the physical address. If it is not, a segment fault will occur.
a) (0, 198) we will check 198< 248, which is true so we will calculate Physical address = 660+ 198 = 858.
b) (2, 156) we will check 156< 198, which is true so we will calculate Physical address = 222+ 156= 378.
c) (1, 530) we will check 530< 422, which is false so segment fault occur.
d) (3, 444) we will check 444< 604, which is true so we will calculate Physical address = 996+ 444= 1440
e) (0, 222) we will check 222< 248, which is true so we will calculate Physical address = 660+ 222= 882
