Faraday-Lenz's law was easy when I was in 12th standard. But it became more complex when I jumped to Engineering. Recently when I was studying about inductors and how they oppose changes in currents, I found out that Faraday-Lenz's Law becomes little weird because based on my observation I found out that this law "doesn't work" (frankly speaking)! Here's the story behind my observation:
Suppose you have an AC voltage source of 240 volts peak and 60 Hz frequency connected to an inductor of 10 mH inductance (wire's resistance is negligible so that the impedance is only due to the reactance of the inductor). Now if I switch on the Ac supply, it is found out that the voltage across the inductor is 240 volt peak and the reactance and current through it is 3.7699 ohms and 63.6622 amps peak. The voltage polarity is as shown.
Now if we apply Kirchoff's Voltage Law to this circuit, it works as expected. But then I don't seem to understand that 'how' this inductor opposes current. Because in my opinion if the inductor opposes current then the polarity markings on the inductor should be reversed then only we can say it generates a back emf. But then the Kirchoff's Voltage Law would not work if the polarity markings are reversed.
Now I think I didn't understood the topic of how inductors oppose currents in an AC circuit.
And also if it generates a back emf to generate a back current then where is the back emf and the back current and why it does not affect the voltage across the inductor and the current through it?
    \$\begingroup\$ Lenz's law gives you the sign of the induced emf when there is a changing magnetic field. So if you put another coil inside the 10mH inductor it would tell you the sign of the induced voltage in the second coil. \$\endgroup\$ Oct 22, 2014 at 13:18
  • \$\begingroup\$ @GeorgeHerold Okay I got it! \$\endgroup\$ Oct 22, 2014 at 13:23
My favorite mental model of the inductor is a flywheel. Force is voltage, current is velocity, and inductance is mass. A flywheel resists changes in speed, as an inductor resists changes in current.
You are probably familiar with Newton's second law, which states that force equals mass times acceleration:
$$ F = ma \tag{1} $$
Acceleration is really change in velocity, so we can write that equivalently as:
$$ F = m \frac{\mathrm dv}{\mathrm dt} \tag{2} $$
That's oddly similar to the definition of inductance:
$$ v = L \frac{\mathrm di}{\mathrm dt} \tag{3} $$
I find keeping this analogy in mind when thinking about inductors makes things more intuitive.
Now, you have an inductor connected to a voltage source. An AC voltage source is analogous to a machine that applies a force in one direction, then the other, in alternation. Remember that it applies a force, but the direction the flywheel is spinning, the current, is unrestricted. At any given moment, the flywheel might be spinning in the direction of the applied force, in the opposite direction, or not at all.
Now, consider what happens at each point in the AC cycle:
  1. When voltage is at a maximum, then according to equation 3, current is increasing at some rate determined by \$L\$.
  2. When voltage is at 0, then current remains constant.
  3. When voltage is at a minimum, then current is decreasing.
In fact, current is increasing for the entire time that voltage is positive. It's increasing fastest when voltage is at the maximum. By the time voltage gets to 0, current has stopped increasing, but current is by now at a maximum, having been increasing for the entire preceding voltage half-cycle.
When voltage crosses the zero point and begins to go negative, the effect is to begin to decrease current, to "slow down the flywheel". Eventually current reaches zero, then begins to go in the other direction. Eventually voltage reverses polarity, and the current begins to be slow, and its direction reversed, and so on.
With a bit of math, you can substitute \$v = \sin(t)\$ into equation 3, and you find that \$i = \cos(t)\$, as in the bottom figure here:
capacitor and inductor V-I phase relationship By Jeffrey Philippson [Public domain], via Wikimedia Commons
Now when you have a larger inductance, that's like a heavier flywheel. If the same voltage (force) is applied to it, then it's harder to get spinning fast. That is, the current is less. That is how inductors oppose AC currents.
Lenz's law is even more intuitive. Suppose you came across a big, heavy, fast spinning flywheel, and you tried to force its speed to zero by grabbing it. The flywheel will push you in some direction, right? This is the "back emf". It is what you get for \$v\$ in equation 3 if you force \$\mathrm di / \mathrm dt\$ to be non-zero.
Lenz's law simply says which direction the shove happens. If you ignore Lenz's law and get the direction wrong, then it becomes possible to create a perpetual motion machine.
  • \$\begingroup\$ I don't understand your statements. When voltage is zero the current is constant verses When voltage is minimum, then current is decreasing. When would 50hz 240V be at minimum in its normal cycle' \$\endgroup\$
    – kingchris
    Oct 22, 2014 at 13:46
  • \$\begingroup\$ @kingchris, half a cycle from its maximum. \$\endgroup\$
    – Phil Frost
    Oct 22, 2014 at 13:51
The key thing to understand in your circuit is that Vs is an ideal voltage source, which means it doesn't control the current at all. The inductor isn't "opposing" current forced from Vs, it's changing its current in response to the voltage applied by Vs. There's no back-EMF because there's no current control. If you replace your voltage source with a sinusoidal current source, then you'll see the inductor develop its own voltage.
In the sinusoidal steady state, we're less interested in energy storage and more interested in phase shifts. From that viewpoint, the important thing is that the inductor's voltage and current are 90 degrees out of phase.
In all cases, the basic inductor equation v = L * di/dt applies.
But an inductor doesn't oppose current, it opposes changes in current. Thus, if the current is changing slowly with time, e.g., a relatively low frequency sinusoidal current, there is lower opposition.
However, if the current is changing rapidly with time, e.g., a relatively high frequency sinusoidal current, there is higher opposition.
By higher opposition, I mean that the voltage across the inductor and, thus, the flow of energy, is higher.
Essentially, the flow of energy to and from the inductor is proportional the rate of change in current. Why?
Increasing the current increases the magnetic field and there is an associated energy thus, the faster the current increases, the faster the magnetic field increases and thus the greater the required flow of energy (power).
But remember, power is given by the product of current and voltage thus, if there is greater power associated with a greater rate of change of current, there must be more voltage associated with a greater rate of change.
To put this in mathematical terms, it's straightforward to derive the following equation for the energy stored in the magnetic field of an inductor:
$$W_L = \frac{1}{2}Li^2$$
where \$i\$ is the current through the inductor.
The associated power is just the time rate of change of the energy:
$$p_L = Li\frac{d_i}{dt}$$
Since, as mentioned before, power is (always) the product of the voltage across and current through, we have
$$v = L \frac{di}{dt}$$
where \$v\$ is the voltage across the inductor.
So, based on energy and power considerations, we see that it must be the case that the voltage across the inductor is proportional to the time rate of change of the current through - the inductor 'opposes' faster changing current more than slower changing current.
