I am basically setting different control signals for the ALU to perform operations in verilog. But I have tried all possible ways of writing what I want but in vain, can you help me out. How should I set these control signals at particular 3 bit alu states;
This is my code, i have all possible assignments; (sorry, its inverteed and i don't know how to rotate it because the website i upload pictures on automatically rotated it this way)
Initial declarations;
input [1:0] op, src, srl, dst_ram_mux, dst_q_mux;
input inv_s, inv_r, sel, dst_ram_en, dst_qen, dst_y, cin, reg_wr, cp;
95 always @(i[5] or i[4] or i[3])
96 begin
97 if( i[5]==0 && i[4] == 0 && i[3] == 0) // this is add S+R
98 begin
99 cin <= 0;
100 assign sel = 0;
101 inv_s <= 0;
102 assign inv_r = i[5] & i[4] & i[3];
103 op[1] = i[5] & i[4] & i[3];
104 op[0] = 0;
105 end
The 'end' for the always is way below at line 327, not seen here
The errors for all assignments;
assign
statement inside a procedural block. If you want to change the value of something inside a procedural block, define it as a reg, and change its value with=
or<=
. \$\endgroup\$ – The Photon Oct 23 '14 at 18:34sel
as a wire or a reg? You need to include all the relevant code if you want our help. \$\endgroup\$ – The Photon Oct 23 '14 at 18:44
