With barely no knowledge in this field, I would like to render my antenna used with Bluetooth BLE devices more directional.
I tried to shield the antenna with different kind of metals with no luck.
Is there someone to point a way in order to render my antenna directional? Perhaps surounding with something?
Thanks
    \$\begingroup\$ yeah, just cut a tin can open and unfold it, and make it like a 'radar dish' pointing in the direction you want. That would only increase receive strength, and only if the receiver can handle multi-path/signal reflections. i think, dont sue me if i'm wrong \$\endgroup\$ – KyranF Oct 24 '14 at 12:05
  • \$\begingroup\$ You'd do better not to disasemble the can. See the old writeups on pringles and 2.4GHz wifi. \$\endgroup\$ – Chris Stratton Oct 24 '14 at 13:05
Since the wavelengthn is quite short (~10 cm) it's very important that the reflector (that can be a can, as proposed) is placed carefully, in a way that the reflected signal is as much as possible in phase with the directed. You achieve this by having the reflecting surfaces at a distance that is multiple to half a wavelength.
You can try to tune it by measuring the signal strength while varying the reflector position, but I wouldn't expect great improvements unless you use a specifically made antenna.
  • \$\begingroup\$ Thank you for your useful comment. I bought this antenna because of its directional characteristic. But, after some tests, it is absolutely not the case... I will try your suggestions. \$\endgroup\$ – sdespont Oct 24 '14 at 19:46
  • \$\begingroup\$ Well, don't expect a directional antenna to be laser-like. It's much more complicated, and you'll have lots of reflections from the surroundings. \$\endgroup\$ – clabacchio Oct 26 '14 at 20:27
