I have the diagram below, but I don't understand how the switches are hooked up. Is that an special switch, or I can achieve that with an special connection? Thank you!
Switch Bypass
    \$\begingroup\$ The dashed line indicates a mechanical coupling between the two parts of the switch. \$\endgroup\$ Commented Oct 24, 2014 at 19:47
That's two switches connected together that can be in either of two positions. It is a DPDT (double-pole, double-throw) switch.
