I just went to go unplug an HDMI cable and got shocked from the end of it! The only possible causes of this that I can think of are that the receiving or sending end of the long (50ft) HDMI cable is introducing a live current into the line, or that an electrical current is being induced in the HDMI cable because it runs side by side (parallel) to a 120v AC extension cable for 15 feet.
Should I be concerned? What are the first steps I should take to diagnose this?
For reference, there was a Sony PS3 connected to one side, and an HDMI Splitter to the other end (http://smile.amazon.com/dp/B00B46XUQU)
If you need any clarification, please don't hesitate to ask!
  • 4
    \$\begingroup\$ Should I be concerned? Technically, electrocution is death caused by electric shock so the first step I would take is to confirm that you have not been electrocuted. Having established that you are in fact alive, I would take the next step of eliminating the concern, however unlikely, that running the HDMI cable next to an extension cord caused the alleged electrocution. By the way, do you have a voltmeter? \$\endgroup\$ Oct 26, 2014 at 2:39
  • \$\begingroup\$ @AlfredCentauri I seem to be fine, but thanks for the disclaimer :) I definitely felt that signature tingle of live current though, so there was something on that wire. I don't have a voltmeter with me, but I have used one before. Assuming I did have one, what should I use it for in this scenario? \$\endgroup\$
    – villasenor
    Oct 26, 2014 at 2:45
    \$\begingroup\$ Michael, if you had a voltmeter, you would set it for "VAC" and you would clip one lead on a convenient ground and the other lead on the exposed metal on the end of the HDMI cable (the part you most likely touched). You shouldn't measure a significant voltage. If you do, there's most likely a serious defect in the device the cable is connected to. As another answer pointed out, it is unlikely that an extension cord could induce a significant current in the HDMI cable. But, you can easily remove that variable, right? \$\endgroup\$ Oct 26, 2014 at 3:11
  • \$\begingroup\$ If the devices all still work I'd put my money on plain-jane static shock. \$\endgroup\$ Oct 26, 2014 at 6:35
4 Answers 4
The coupling could result from a Y-capacitor in the HDMI switch power supply. A Y-capacitor is placed between L-GND and N-GND and often used to filter out common-mode noise and to establish a common ground reference (with respect to "earth").
If the outlet / plug does not provide proper grounding (only N and L connected) and you touch GND on the HDMI cable, there might be a small current between flowing from L-GND-YOU-EARTH. Y-capacitors are tested to applicable standards to qualify them as safe. They never fail as "short" and there are typically only a few uA flowing, but it is enough to feel a tickle.
It's not likely that a 120v power cord induced a significant voltage in the HDMI cable. Voltage induced by wire A in a wire B is proportional to the amount of current flowing in wire A and is transferred by the magnetic field. However your power cord has both hot and neutral lines, and they carry (nearly) the same amount of current in opposite directions. This means the magnetic field is cancelled out, except for minute variances between the current in the lines.
What's more likely is that device on the other end is badly designed so that it's not grounded, not properly isolated from the HDMI plug or broken/damaged.
Since you are unplugging the cable, is it safe to assume that it's still connected at the other end? Was it the PS3 or another device?
    \$\begingroup\$ Thanks for the awesome response! The device that was still connected on the other end was the cheap HDMI Splitter from Amazon. I was unplugging my PS3 at the time. The HDMI Splitter has a 5V 2000mA optional power adapter connected to it. Do you think it is a faulty power adapter for the HDMI Switch, or the actual switch itself? Thanks again \$\endgroup\$
    – villasenor
    Oct 26, 2014 at 3:27
    \$\begingroup\$ I'd suspect the splitter itself. The power adapter is probably a stock "wall wart" which they sourced from another company. Try removing the HDMI cable from the splitter, plug in the PS3 and briefly touch the metal casing on the other end to see if you have the same experience. Once you're sure it's not the PS3, focus on the splitter. Try the experiment without the power adapter and with. \$\endgroup\$
    – kronenpj
    Oct 26, 2014 at 3:35
If it is 50 feet long and you are using devices fed from different circuit breakers or from a circuit supply a lot of power to other devices, it is more likely that "ground" is not the same at the two ends of the cable. A current carrying wire can not be at ground potential and inside buildings the neutral wire can vary in voltage from place to place depending on loads. I have seen as much as 40 volt difference in large buildings. It can be quite dangerous to run long extension cords and cables that connect to power sources on different circuits. This is why there have been standards for ages that say doorbells are run from low voltage isolation transformers.
Check with a voltmeter to see the difference between the neutral side of the outlet (I'm talking U.S.A. here) which is the wide slot and earth ground which is the round hole - and should not be carrying any current. It is there in case of a short so the circuit breaker will blow, instead of you or a fire. If it is old and there is no ground plug, the screw that holds the plate might be grounded.
Of more interest is exactly how did you get the shock? What else were you touching? What is the floor material and did you have shows on?
It didn't harm you so that is good but, does it suggest a darker and more serious problem that could be classed as potentially life threatening?
My belief is that the power source that caused the "tingle" is a switched mode power supply and a little bit of AC current is leaching thru the EMI reduction capacitors. If it is this it is quite common and not dangerous but it ought to be a small wake up call for you to double check this by seeing if touching either of the wall wart's dc wires can produce a similar effect. If it does then I'm fairly convinced that all is well.
  • \$\begingroup\$ I touched the barrel connector on the end of the wall wart that attaches to the HDMI switch and did not get a shock. Should I be concerned? Does this indicate a problem with the HDMI circuitry? \$\endgroup\$
    – villasenor
    Oct 26, 2014 at 3:32
    \$\begingroup\$ I'd be concerned because I suspect something else is causing this problem. There are doubts forming about the integrity. Induction shouldn't be enough to explain this a la the other answer. \$\endgroup\$
    Oct 26, 2014 at 3:52
